What Volume Flow Rate Maintains Equal Pressure in Two Connected Pipes?
  • Thread starter Thread starter biophys
    Flow Liquid
The discussion focuses on calculating the volume flow rate required to maintain equal pressure in two connected pipes with differing diameters and a vertical height difference. The Bernoulli equation is utilized, specifically the form that relates pressure, velocity, and height in fluid dynamics. The key equation derived is Q = v_1A_1 = v_2A_2, where A_i represents the cross-sectional area of the pipes. The solution involves equating pressures and solving for the volumetric flow rate Q, taking into account the height difference of 8.2 m and the radii of the pipes (0.0200 m and 0.0410 m).
  • Understanding of the Bernoulli equation for fluid dynamics
  • Knowledge of volumetric flow rate and cross-sectional area calculations
  • Familiarity with concepts of steady, frictionless, incompressible flow
  • Basic principles of pressure differentials in fluid systems
  • Study the application of the Bernoulli equation in various fluid flow scenarios
  • Learn how to calculate cross-sectional areas for different pipe diameters
  • Explore the implications of height differences on fluid pressure and flow rates
  • Investigate the effects of viscosity in real fluid flow situations
Engineers, physicists, and students in fluid dynamics or mechanical engineering who need to understand the principles governing fluid flow in connected systems.
biophys
Please help me with the following:
"A liquid is flowing through a horizontal pipe whose radius is 0.0200 m. The pipe bends straight upward through a height of 8.2 m and joins another horizontal pipe whose radius is 0.0410 m. What volume flow rate will keep the pressures in the two horizontal pipes the same?"
Here is my reasoning, that doesn't seem to be working out.
- first of all, the problem just says "liquid" so I know that I can't possibly need to know specific density.
-The equation for volume flow rate [ pi*R^4*(P2-P1) ] / (8*viscosity*L)
doesn't really make sense for this problem, how would I find the vidcosity and wouldn't (P2-P1) be zero anyway?
?? Thanks
Use the Bernoulli equation (you'll have to assume steady, frictionless, incompressible flow along streamlines):
[tex]\frac p \rho + \frac {v^2} 2 + gz = {\rm constant}[/tex]
You want to solve for the volumetric flow rate (which I'll call Q) which, by mass continuity and our assumptions above can be shown to be:
[tex]Q = v_1A_1 = v_2A_2[/tex]
(subscripts denote first position and second position; [tex]A_i = \pi r_i^2[/tex])
So:
[tex]\frac{p_1}{\rho_1} + \frac{Q^2}{2A_1^2} + gz_1 = \frac{p_2}{\rho_2} + \frac{Q^2}{2A_2^2} + gz_2[/tex]
since we're solving for the case where p1 = p2 (and ρ1 = ρ2 because it's the same liquid), the first term on the left hand side of the equation cancels with the first term on the RHS. Solve the equation for Q and plug in the known quantities (z is the height of the fluid in the equations).
So:
[tex]\frac{p_1}{\rho_1} + \frac{Q^2}{2A_1^2} + gz_1 = \frac{p_2}<br /> {\rho_2} + \frac{Q^2}{2A_2^2} + gz_2[/tex]
Yes, I'm with jamesrc. It has no sense thinking of how to solve this problem using viscous flow, because in it a loss of pressure is assured notwithsanding what volume flux is used.
  • · Replies 38 ·
