How Do You Calculate Deceleration and Angular Acceleration of a Bowling Ball?
The discussion revolves around calculating deceleration and angular acceleration of a bowling ball as it transitions from sliding to rolling on a bowling alley. The problem involves concepts of linear motion, friction, and rotational dynamics.
  • Mixed
  • Participants explore expressions for linear deceleration and angular acceleration, with some questioning the correctness of the original poster's approach to angular acceleration.
  • There are discussions about the role of friction and its impact on the motion of the ball, particularly regarding when it stops sliding and starts rolling.
Some participants have provided feedback on the original poster's calculations, indicating that while some parts appear correct, there are significant concerns regarding the angular acceleration calculation. The discussion is ongoing, with participants clarifying concepts and exploring the implications of friction on the ball's motion.
There is a focus on ensuring that the calculations account for the transition from sliding to rolling, which affects the forces and accelerations involved. Participants emphasize the importance of determining the time at which friction ceases to act in order to fully understand the motion of the ball.
Nylex
I just want to check if my answers for these are right so far.
"Consider a ball of mass M and radius R being bowled in a bowling alley. The ball is released with velocity v0. As it makes contact with the wooden floor (of coefficient of friction, μ), the ball slows down and begins to rotate. It is both sliding and rotating."
Write down expressions for:
i. the linear deceleration
Frictional force, F = -μN = -μMg
N II: -uMg = Ma
=> a = -μg
ii. the angular acceleration
Not sure here
α = a/R, but a is -ve, which would mean α is negative :/
iii. the speed of the centre of the ball after time t
v = u + at
v = v0 - μgt
Not quite sure about this one either, cos it's worth 2 marks :/
Thanks.
ii) is completely incorrect; that formula relates TANGENTIAL acceleration at the rim of a fixed rotating with the angular acceleration.
What you need to do is:
Find the torque produced by the force of friction with respect to the center.
The angular acceleration is then found by the ratio between the torque and the moment of inertia.
Lol, ok. Thanks. What about the others?
They look fine.
Cheers :).
Note however, that in iii), the force of friction will STOP acting on some T (when the ball starts only to roll, not sliding).
Hence, in order to gain full marks here, you must determine T; after that, the centre of the ball moves with CONSTANT velocity
Yeah, that's for the next part of the question.
15K
