| New Reply |
[abstract algebra] is this ring isomorphic to... |
Share Thread | Thread Tools |
| Aug4-11, 12:05 AM | #1 |
Consider [itex]\frac{\mathbb Z_2[X]}{X^2+1}[/itex], is this ring isomorphic to [itex]\mathbb Z_2 \oplus \mathbb Z_2, \mathbb Z_4[/itex] or [itex]\mathbb F_4[/itex] or to none of these? 2. Relevant equations / 3. The attempt at a solution - [itex]\mathbb F_4[/itex] No, because [itex]\mathbb Z_2[X][/itex] is a principle ideal domain (Z_2 being a field) and X²+1 is reducible in [itex]\mathbb Z_2[X][/itex] and in a principle ideal domain an ideal formed by a reducible element is not maximal and thus the quotient is not a field - [itex]\mathbb Z_4[/itex] No, as it can obviously not be cyclical - [itex]\mathbb Z_2 \oplus \mathbb Z_2[/itex] No. Because say there is an isomorphism [itex]\phi: \frac{\mathbb Z_2[X]}{X^2+1} \to \mathbb Z_2 \oplus \mathbb Z_2[/itex], then say [itex]\phi(X) = (a,b)[/itex], then [itex]\phi(1) = \phi(X^2) = \phi(X)* \phi(X) = (a^2,b^2) = (a,b)[/itex] since a and b are either zero or one. As a result "1" and "X" would have the same image. Contradiction. Is this correct? If so, does this also seem like a good way to do it, or did I overlook an easier way to do this? |
| Aug4-11, 08:55 AM | #2 |
It seems to be correct!! And you also used a very nice method to show this
![]() If you don't want to work with the isomorphism in (3), then you could perhaps say that [itex]\mathbb{Z}_2\oplus\mathbb{Z}_2[/itex] has no nilpotent elements, while [itex]\mathbb{Z}[X]/(X^2+1)[/itex] does. |
| Aug4-11, 11:13 AM | #3 |
Aha true :) thank you
| New Reply |
| Thread Tools | |
Similar Threads for: [abstract algebra] is this ring isomorphic to...
| Abstract Algebra, Division Ring question | Calculus & Beyond Homework | 1 | ||
| Abstract algebra--> Let R be a ring and let M2(R) be the set of 2 x 2 matrices with | Calculus & Beyond Homework | 0 | ||
| Abstract Algebra: Ring Theory Problems | Calculus & Beyond Homework | 2 | ||
| abstract algebra (ring theory) | Calculus & Beyond Homework | 1 | ||
| Abstract Algebra: Isomorphic polynomial rings | Calculus & Beyond Homework | 2 | ||
