Proving Unitary Operators = e^iA for Self Adjoint Matrix
  • Thread starter Thread starter skyroot
    Operators
The discussion centers on proving that a unitary operator U in the vector space of complex n x n matrices can be expressed as U = eiA, where A is a self-adjoint matrix with eigenvalues in the interval [0, 2π]. The proof confirms that if U = eiA, then U is unitary, as demonstrated by showing that UU* = I. The challenge lies in proving the converse: whether every unitary operator can be represented in this form. The participant ultimately resolves their query, indicating that they found the solution.
  • Understanding of self-adjoint matrices and their properties
  • Knowledge of unitary operators and their definitions
  • Familiarity with matrix exponentiation, specifically eiA
  • Concept of diagonalization of matrices and unitary equivalence
  • Study the properties of self-adjoint matrices in detail
  • Explore the implications of the spectral theorem for unitary operators
  • Learn about the relationship between unitary operators and their eigenvalues
  • Investigate counterexamples in linear algebra to understand limitations of matrix representations
Mathematicians, physicists, and students studying linear algebra, particularly those focusing on operator theory and quantum mechanics.
skyroot
Prove or disprove: if U is in the vector space of complex n x n matrices, then U is unitary if and only if U= e^iA, where A is some self adjoint matrix in same vector space, all of whose eigenvalues lie in the interval [0,2pi)
A is self adjoint; A* = A, and A is unitarily equivalent to a diagonal matrix, A=PDP*, where P is a unitary matrix whose columns consist of eigenvectors of A which form an orthonormal basis for the vector space.
e^iA= P(a diagonal matrix with first entry, D'11= e^it1, and last entry D'nn=e^itn)P* . Where t1 thru tn
are the (real) eigenvalues of A, and P is the matrix defined above.
Unitary operators:
UU*= I , the defn of unitary
Unitary operators are normal, all eigenvalues have abs value 1, and ||Uv|| = ||v|| for any vector in the vector space U is acting on.
I've proved it one of the directions, starting by assuming U=e^iA, putting it into the form i described above, and showing U*=e^-iA, simply multiplying UU* gives I, which is the defn of unitary operator. I think I need a small hint for how to approach the proof from the other direction,i.e. starting with assuming that U is unitary can one show that it equals e^iA for some self adjoint A. Questioning if only the first direction is true, and if the other direction can be proved at all. Trying to think of a counterexample. Thank you for your help.
Nevermind, i got it
  • · Replies 19 ·
15K
