derivative of the pi function
by 3.14159253589
Tags: derivative, function
3.14159253589
3.14159253589 is offline
#1
Aug6-11, 02:10 AM
P: 5
What is the derivative of the pi function
Phys.Org News Partner Science news on Phys.org
Lemurs match scent of a friend to sound of her voice
Repeated self-healing now possible in composite materials
'Heartbleed' fix may slow Web performance
dimension10
dimension10 is offline
#2
Aug6-11, 02:27 AM
P: 371
If you are talking about the prime number thing, I am not sure about the exact one but here is an approximation:
[tex]\pi(n)\approx \int_{2}^{n}\frac{dt}{\mbox{ln}(t)}[/tex]
[tex]\frac{d}{dn}\pi(n)\approx \frac{d}{dn}\int_{2}^{n}\frac{dt}{\mbox{ln}(t)}[/tex]
[tex]\frac{d}{dn}\pi(n)\approx \frac{d}{dn}\lim_{\delta t \rightarrow 0}\sum_{t=2}^{n}\frac{\delta t}{\mbox{ln}(t)}[/tex]
As the derivative of a sum is the sum of the derivatives,
[tex]\frac{d}{dn}\pi(n)\approx \lim_{\delta t \rightarrow 0}\sum_{t=2}^{n}\frac{d}{dn}\frac{\delta t}{\mbox{ln}(t)}[/tex]
[tex]\frac{d}{dn}\pi(n)\approx \lim_{\delta t \rightarrow 0}\sum_{t=2}^{n}-\frac{\delta t}{n \; {\mbox{ln}}^{2}(n)}[/tex]
[tex]\frac{d}{dn}\pi(n)\approx - \int_{2}^{n}\frac{dt}{n \; {\mbox{ln}}^{2}(n)} [/tex]
So that is the approximate rate of change of the pi function of t as t changes.
I like Serena
I like Serena is offline
#3
Aug6-11, 10:55 AM
HW Helper
I like Serena's Avatar
P: 6,189
This is not quite right.
The proper derivative is:
[tex]\frac{d}{dn}\pi(n)\approx \frac{d}{dn}\int_{2}^{n}\frac{dt}{\ln(t)} = \frac{1}{\ln(n)}[/tex]
dimension10
#4
Aug6-11, 07:29 PM
P: 371
Quote Quote by I like Serena View Post
Then where did I make a mistake?
dimension10
#5
Aug6-11, 07:38 PM
P: 371
According to Wolfram Alpha,
[tex] \frac{d}{dn}(\int_{2}^{n}\frac{dt}{\ln(t)})=\frac{-n+n\; \mbox{ln}(n)+2}{n \;{\mbox{ln}}^{2}(n)}[/tex]
that is,
[tex] {\mbox{ln}}^{-1}(n)+(2{n}^{-1}{\mbox{ln}}^{-2}(n))-{\mbox{ln}}^{-2}(n)[/tex]
But for Li(n) alone, it gives [tex]{\mbox{ln}}^{-1}(n)[/tex] which is your solution.
And my solution gives [tex]- \int_{2}^{n}\frac{dt}{n \; {\mbox{ln}}^{2}(n)}[/tex] which is equal to [tex]\frac{n-2}{n\; {\mbox{ln}}^{2}(n)}[/tex]
I guess all three solutions are equal to each other and thus, correct?
MathematicalPhysicist
MathematicalPhysicist is offline
#6
Aug6-11, 11:06 PM
P: 3,170
Quote Quote by dimension10 View Post
I believe the problem is here:
The derivative operator [tex]\frac{d}{dn}[/tex] should operate on the sum.
I am not even sure what it means to have delta t inside a sum where t is a dumby variable, and then taking a limit of it as it approaches zero, the notation here is quite problematic.
I like Serena
#7
Aug7-11, 03:36 AM
HW Helper
P: 6,189
As MathematicalPhysicist already said, the first mistake is when you moved d/dn to the other side of the summation symbol.
This is not allowed, because the summation is dependent on n.
You made another mistake when you differentiated the expression dependent on t with respect to n.
Since the expression is not dependent on n, the result is zero.
How did you get WolframAlpha to say that?
I do not get that.
The three solutions are not equal to each other, so they cannot all be correct.
dimension10
#8
Aug10-11, 04:51 AM
P: 371
Thanks. I forgot about that.
Oops.
I do not get that.
I think I know what happened. It must have again considered d as constant rather than an infinitesimal.There seems to be a simpler solution using the second fundamental theorem of calculus and that would yield
[tex]\frac{1}{\mbox{ln}(n)}[/tex]
which is the answer given by you.
zetafunction
zetafunction is offline
#9
Aug31-11, 10:28 AM
P: 399
the derivative of the prime counting function is just the sum
[tex] \delta (x-p) [/tex] taken over all primes 'p'
Robert1986
Robert1986 is offline
#10
Aug31-11, 07:21 PM
P: 828
I am confused; pi is a step function and is therefore only differentiable at the "interior" of a step at which point it is 0.
zetafunction
#11
Sep8-11, 10:32 AM
P: 399
yes but since the step function is discontinous delta function appear whenever the function has discontinuties, in the case of Pi function the discontinuities are located at the prime numbers
Register to reply
Related Discussions
prove that derivative of the theta function is the dirac delta function Advanced Physics Homework 3
find derivative of floor function using limit definition of derivative? Calculus & Beyond Homework 10
function --- derivative (help!) Calculus & Beyond Homework 2
First & Second derivative of a function Calculus & Beyond Homework 5
derivative of function Calculus & Beyond Homework 5
