Power is the measure of rate of change of energy in any circuit,then
The discussion revolves around the concept of power as the rate of change of energy in electrical circuits. Participants explore how energy changes occur within circuits, particularly in relation to voltage, current, and resistance.
  • Exploratory, Technical explanation, Conceptual clarification
  • One participant questions how energy changes in a circuit, seeking clarification on the mechanisms involved.
  • Another participant suggests that the power supply acts as the energy source, and that manipulating current or voltage influences energy transfer.
  • A different viewpoint emphasizes maintaining constant resistance while varying voltage or current to observe changes in power, using the example of a light bulb to illustrate this effect.
  • Additionally, a participant notes that in a DC circuit, while voltage and current may remain constant, the temperature of components can vary, indicating that energy can manifest in forms other than electrical energy.
Participants present multiple perspectives on how energy changes in circuits, indicating that there is no consensus on a singular explanation or model.
Participants do not address potential limitations or assumptions regarding the definitions of energy, power, or the specific conditions of the circuits discussed.
This discussion may be of interest to those exploring electrical engineering concepts, particularly students or individuals seeking to understand the relationship between power, energy, and circuit behavior.
amaresh92
power is the measure of rate of change of energy in any circuit,then how the energy is changing in any circuit or how the change in energy happens in circuit?
thanks.
Keep the resistance of the circuit at constant value. And then within permissible limit change the value of either voltage or current, you ll be able to feel the change of power. The classic example is, lighting a bulb. Try to increase voltage given to the bulb, you will see more illumination..
And for a DC circuit, voltage and current might be constant but temperature of components likely isn't. The energy supplied by the source can take many non-electrical forms too.
  • · Replies 16 ·
