New Reply
Stress, Deflection for a simply supported beam with UDL applied
Share Thread Thread Tools
Aug11-11, 02:20 PM   #1
Could anyone please tel me how to calculate the Bending Stress, Compressive stress and the Deflection for any beam (UB 203x102x23) subjected to Uniform Distributed Load of 8063 N/m over a 8 m long beam (simply supported beam).
Thanks all.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Aug11-11, 03:02 PM   #2
Recognitions:
Gold Membership Gold Member
This sounds like a pretty straightforward question, is it homework? Have you tried coming to a solution yourself?
Aug11-11, 03:30 PM   #3
Quote by Mech_Engineer View Post
Yes I did, can you check my result.
Length = 8m
UDL = 8063 N/m
Comp Stress = Load /Area
= (8063*8)/(8*.1018)
= 79204.32 N/m^2
Bending Stress = (Force * Distance)/(I/(D/2))
= (8063*8*8)/((2.11*10^-5)/(0.2032/2))
= 2484779678 N/m^2 for x-axis
For y-axis
= (8063*8*8)/((2.11*10^-5)/(.1018/2))
= (1244835488 N/m^2
Deflection at the center = 5wL^4/384EI
= (5*8063*(8^4))/(384*(200*10^9)*(2.11*10^-5)
= .1019 m
So did I do it right? Thanks for your reply.
Aug12-11, 06:27 AM   #4
My question is, if I apply a point load or UDL I should get the stress in N/m^2. When using UDL is N/m or N/mm, calculating Compressive Stress is Load/ Cross-section Area. The load should be given in N, so I converted N/m UDL to N by multiplying it with my length. Then I get the stress in N/m^2.
Calculating Bending Stress is Force x Distance/(Moment of Inertia/Section Modulus). Here again the force should be in N, so my UDL x length gives me load or force. I get the stress in N/m^2.
What I am doing is right or what? Any one please answer.
Aug12-11, 06:39 AM   #5
Recognitions:
Homework Helper Homework Help
Draw a shear and moment diagram and you will find out why the units in your moment equations are not working out.
Aug12-11, 07:30 AM   #6
I don't mean to say my units are wrong. They sound right to me, but the actual problem is I have a weight of 49 N sitting on four beams connected to each other. And the beam ends are supported by columns (fixed firmly to the columns) restraining the moment in all directions and the beams are held at 5 mts. If you imagine there are four beams connected each other to make a rectangular connection and four columns at each ends of 5 mt height. With load of 49 N, I am converting it into N/m (UDL). I used this formula ( I don't know if it is right or not).
W(UDL) = ws/3 * (3-m^2)/2, m=S/L, S= 4 m, L=8 m, w = 49.
W(UDL) = 89.83 N/m This is the weight over all the beams. When I apply it in the formula for Compressive Stress and Bending Stress, I have to convert it into N to get the units in N/m^2.
My question is, what I am doing is right?? This I came up with my own solution, but I just wanna verify it.
Aug12-11, 10:19 PM   #7
nvn
Recognitions:
buytree: I am currently not understanding your explanation. In post 1, you said UDL = 8063 N/m, but in post 6, you said UDL = 89.83 N/m. That is a big difference. Figuratively speaking, a load of 49 N is nothing. Is this a school assignment?
Also, you did not define your parameters in post 6. And you did not explain how you derived the equation in post 6. Hint 1: In your bending stress calculation in post 3, didn't you forget to divide by 8? Try again.
Aug15-11, 12:45 PM   #8
1#The UDL is 89.83 N/m (In post #1 my calculation is wrong). The load 49N is what I used in my old project, I just considered the same load.
2#Parameters for #6, L-Length of the section, S-Width, w-load over the support. The equation W (UDL) was taken from structural hand book which I downloaded from web. I am not sure how did they derive it.
3#I did a project when in school which included similar calculation but with a point load. One of my juniors had some question about my project, then I started thinking how does it change with UDL applied.
4#I remember the formula for bending stress, (WL^2)/8. But I tried to used the actual bending stress formula which is Bending Stress = (Force * Distance)/(I/(D/2)), I-moment of inertia, D-Depth of the beam. I am pretty sure this is the right formula. I really don't know how different these two formulas are.
Aug15-11, 08:11 PM   #9
nvn
Recognitions:
buytree: Bending stress for a simply-supported beam with a UDL (w) would be, sigma = M*c/I = [(w*L^2)/8](0.5*D)/I. By the way, N/m^2 is called Pa. And 10^6 Pa is called MPa.
Aug16-11, 06:56 AM   #10
Thanks nvn. The Bending Stress formula you gave makes sense to me.
The compressive stress is Force/Crossection Area, Weight(49)/(Length(8)*Width(0.2036)) which gives unit in Pa.
I am finding the combined stress for beam, which is
=(cal compressive stress/allowable comp stress) +(cal bending stress in x/allow bend stress)+(cal bending stress in y/allow bend stress) which should be less than 1 according to IS800 code book. It is not giving a value less than 1. Am I doing anything wrong. If needed I don't mind attaching my work sheet. Thanks again.
New Reply
Thread Tools
Similar Threads for: Stress, Deflection for a simply supported beam with UDL applied
Thread Forum Replies
Simply Supported Beam Safe load Engineering, Comp Sci, & Technology Homework 33
If a uniform beam was in space and only was applied a force on one side...(Stress) Classical Physics 7
Radius of Curvature in a simply supported beam Introductory Physics Homework 7
Finding shear and moment diagrams for a simply supported beam. Engineering, Comp Sci, & Technology Homework 1
Simply Supported Beam Mechanical Engineering 2
