Steady State Error of a PI Controlled System (parabolic input)
The discussion focuses on determining the steady state error (ess) of a PI controlled robotic joint system with a parabolic input. The user, Sam, calculated the integral gain (Ki) required for ess to equal 5% and found Ki to be approximately 0.0011917. However, Sam encountered issues in Simulink, particularly with modeling the parabolic input and the PI controller. The community provided insights on using transfer function blocks and suggested utilizing the sisotool for verification.
  • Understanding of PI control systems and their transfer functions
  • Familiarity with Simulink for modeling control systems
  • Knowledge of steady state error calculations in control theory
  • Experience with Routh-Hurwitz stability criterion for closed-loop systems
  • Learn how to implement parabolic inputs in Simulink
  • Explore the use of the sisotool for control system analysis
  • Study the Routh-Hurwitz stability criterion in depth
  • Investigate the effects of external disturbances on control system performance
Control engineers, robotics developers, and students studying control systems who are looking to optimize PI controller performance and understand steady state error in dynamic systems.
Saam
Hey guys/gals,
The block diagram attached is a PI controlled robotic joint system where:
G(s)=Kp+(Ki/s)
P(s)=48500/(s^2+2.89s)
R(s)= joint’s desired angular position
C(s)= joint’s angular position
D(s)= external disturbance
G(s)= PI controller
ess= Steady State Error
My problem:
A) Find the value Ki that will result in ess=5% for a parabolic input.
B) Using this value of Ki find the range of Kp for closed-loop stability.
My solution:
ess=1/Ka=0.05
Ka=lim(s>0) s^2G(s)P(s)=20
G(s)P(s)=((sKp+Ki)/s)(48500/(s^2+2.89s))
=(48500sKp+48500Ki)/(s^3+2.89s^2)
=(48500sKp+48500Ki)/(s^2(s+2.89))
Ka=48500Ki/2.89=20
Ki=20*2.89/48500
Ki=0.0011917
I tried using this Ki value in my Simulink model (other attachment) but the system didn’t have any steady state error, and I could only manage to get steady state error by making Ki = 0.
Also, I didn’t know how to insert a parabolic input into Simulink so I used this instead:
Ramp x Ramp x 0.5 to represent (½)t^2
My questions:
1) Is my parabolic input correct?
2) Is my PI controller set out correctly in my Simulink model? (I wasn’t sure how to model the I component)
3) For this part of the question I’ve been ignoring the disturbance (D(s)), it’s not mentioned in this part, is it ok to ignore?
4) Am I going about finding Ki the right way?
5) What path should I take to get Kp after I have Ki? I’m thinking I need to do a Routh array.
Looking for a little nudge toward the right path.
Thanks for the help,
Sam
1) try two transfer function blocks [1/s] in series. (Although I suspect what you're doing is equivalent)
2) It is correct, although there is PID controller block.
3) There is no model of D(s) given so you can assume nothing helpful.
4) Looks like you're on the right track but its too late to check numbers right now.
5)You can do that.
Hint: You can check your answer (or solve the problem) using sisotool.
  • · Replies 0 ·
