| New Reply |
current through resistor, with heat. What happens to the current? |
Share Thread | Thread Tools |
| Aug17-11, 05:38 AM | #1 |
Suppose a current of 1 A is flowing through a resistor. If this makes the resistor heat up, will the current through the resistor increase, decrease, or remain constant? Assume the voltage applied to the resistor is constant. 2. Relevant equations 3. The attempt at a solution Please help me with this, i'm not sure, but I believe the current will decrease slightly because of the heat dissipated? |
| Aug17-11, 06:19 AM | #2 |
Recognitions:
| Aug17-11, 07:48 PM | #3 |
Okay, so as the wire heats up the resistance of the wire increases, this causes the current to decrease. Is that correct?
| Aug17-11, 08:32 PM | #4 |
Recognitions:
current through resistor, with heat. What happens to the current?EDIT: provided the resistor is made using wire. |
| Aug17-11, 10:01 PM | #5 |
The current decrease is NOT because of the heat dissipated. For an ideal resistor that does not change resistance even if it heats up, the current doesn't change.
| New Reply |
| Thread Tools | |
Similar Threads for: current through resistor, with heat. What happens to the current?
| Which resistor has most current? | Introductory Physics Homework | 1 | ||
| Current through a Resistor | Introductory Physics Homework | 12 | ||
| induced current through a resistor - with variable resistor and two coils | Introductory Physics Homework | 15 | ||
| current through each resistor | Introductory Physics Homework | 8 | ||
| current through resistor | Introductory Physics Homework | 2 | ||
