Specifying equation under variable transformation
The discussion focuses on the invariance of a dynamical system represented by three equations. The user initially integrates the equations incorrectly, leading to a misunderstanding of the dependency of variables on time. The correct approach involves defining new coordinates (X = -x, Y = -y, Z = z) to verify the invariance of the system under the transformation (x,y,z) → (-x,-y,z). The key takeaway is that proper handling of time-dependent variables is crucial in solving differential equations.
  • Understanding of dynamical systems and their equations
  • Familiarity with differential equations and their solutions
  • Knowledge of variable transformations in mathematical contexts
  • Basic integration techniques in calculus
  • Study the methods for solving time-dependent differential equations
  • Learn about variable transformations and their applications in dynamical systems
  • Explore the concept of invariance in mathematical physics
  • Review integration techniques specific to systems of equations
Students and researchers in mathematics, physics, and engineering who are working with dynamical systems and require a deeper understanding of invariance and differential equations.
k0um0njin
For the following dynamical system in the attached picture
What is the appropriate way to specify the equation is invariant? Thanks in advance.
No relevant equations
Firstly I integrated each of the three equations and the results
x = 10yt - 10xt- -①
y = rxt - yt - xzt -②
z = xyt - 8/3(zt) -③
From equation ③, I got z = (txy)/ (1 + 8/3t) and
then, I substitute the equation of z into the equation ②. Until this point, am I doing it right?
The most straightforward way to verify an invariance is by defining new coordinates and checking that the new variables satisfy the same equations as the old variables. Since the claimed invariance is [itex](x,y,z)\rightarrow (-x,-y,z)[/itex], you should define
[itex]X = -x, ~ Y=-y,~Z=z.[/itex]
As an aside, your integration of the equations is incorrect. Since the [itex]x,y,z[/itex] are functions of [itex]t[/itex], solving the differential equations is more complicated than what you've done, which ignored this dependence.
