New Reply
Power calculations for Hovering
Share Thread Thread Tools
Aug20-11, 09:23 PM   #1
Hi,
I have a very basic question. Theoretically,I need to make a load hover (in real terms i'm makin a heli).
I wanted to do the calculations for how much power is needed by the prime mover (engine/motor doesn matter) to hover. i.e to give thrust(T) = weight of (load+Motor).
Can someone please tell me this equation that relates Power(P) and Thrust(T) at zero velocity i.e hovering.
Dont worry about prop diameter/aerodynamic characteristics etc at this moment. I'm just looking for the minimum power of the prime mover(energy source) to give me the ability to hover a certain weight
Thanks!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Aug22-11, 12:48 AM   #2
Unfortunately it's not that simple.
The formula for power is quite simple: Force x Velocity. So the quick answer to your question is that no matter how much your load weighs, the minimum power required is "0", since your velocity is zero. If you think about it, this is precisely true...after all, how much power does it take for the ground to hold up a mountain?
Obviously this isn't the answer you're looking for. A helicopter is not supported by the ground, but by the air. It does this by accelerating a mass of air down, with the reaction keeping it up. The greater this mass of air that is accelerated the closer you can get to the theoretical "0" requirement. Essentially this means that the larger your propeller diameter, the less power you need.
New Reply
Thread Tools
Similar Threads for: Power calculations for Hovering
Thread Forum Replies
3phase power calculations Electrical Engineering 6
Harmonics in power calculations Electrical Engineering 2
Basic AC power calculations Engineering, Comp Sci, & Technology Homework 7
AC power calculations: Engineering, Comp Sci, & Technology Homework 1
Power calculations Mechanical Engineering 2
