Calculating Molecular Geometry Angles
The discussion revolves around calculating molecular geometry angles, particularly focusing on the angles formed by electron repulsion in molecular structures. Participants explore concepts related to vector calculations, VSEPR theory, and the implications of electron pairs on molecular geometry.
  • One participant suggests using vector analysis to calculate angles between electron repulsion, proposing a method involving the arc-cosine of the dot product and norms of vectors.
  • Another participant references VSEPR theory, indicating that the presence of non-bonding electron pairs affects molecular geometry and can lead to deviations from ideal angles.
  • A different participant notes specific angles associated with different numbers of electron pairs, mentioning that two pairs yield 180º, three pairs yield 120º, and four pairs yield approximately 108º.
  • One participant challenges the reasoning regarding electron pairs and bonding, referencing the octet rule and the limitations on bonding based on the number of available electrons.
Participants express differing views on the reasoning behind molecular geometry and the application of the octet rule, indicating that multiple competing perspectives remain without a clear consensus.
There are unresolved assumptions regarding the application of vector mathematics to molecular geometry and the implications of the octet rule on bonding capabilities.
This discussion may be of interest to students and professionals in chemistry and physics, particularly those exploring molecular geometry and electron interactions.
relativitydude
Howdy,
I'm trying to calculate the angles between the repulsion of electrons. Well, it looks like a vector problem. Basically, can I just think of 360º between each of the individual the XY, XZ, and YZ planes. If I set everything up with generic variables to everything, will they drop out at the end so I can get the separation in degrees in the respective XY, XZ, and YZ planes, then finally taking the arc-cosine of the dot product divided by the norm of the vectors for an overall angle?
Chemistry news on Phys.org
Are you studying VSEPR theorem, namely Valence Shell Electron Pair Repulsion?
You may use these basic knowledge:
  1. If the central atom has no non-bonding electron pair, the geometry should be an ideal one.
  2. If one non-bonding electron pair is present, bonding electrons escape from it, thereby causing a deviation of geometry.
  3. If more than one non-bonding electron pair is present, repulsions among non-bonding electron pairs must be neutralized first (refer to seesaw geometry of XeF2).
Well, when we have two pairs that's 180º and when we have three pairs, that's 120º, that's simple. However, four pairs is ~108º
Having that extra dimension really complicates thing. I would like to know from a physics point of view via vectors on how to calculate it.
Well, I'm not sure your reasoning is absolutely correct. In octet rule, we assume that a maximum of 8 electrons for atoms except hydrogen are available, so if there are three n-electrons on an atom, only one bonding will be possible. If there is four, it is essentially a noble gas like argon, etc. (not Helium; the total number is 2 in this case).
If you wonder it from physics point of view, make sure some physicists read this post by posting a small message and including the url to this thread.
20K
