Proof of limit involving square root
The discussion revolves around proving the limit of the expression involving square roots as n approaches infinity. The limit in question is lim (sqrt(n+1) - sqrt(n)) * sqrt(n + 1/2) = 1/2.
  • Participants explore various methods to manipulate the limit expression, including rewriting terms and applying algebraic techniques. Some participants express confusion about the limit's existence based on the initial formulation.
Several participants have contributed different approaches to the limit, with some suggesting algebraic manipulations and others proposing a sandwich theorem method. There is recognition of the complexity of the problem, and while some solutions are presented, there is no explicit consensus on a single method.
Participants question the original formulation of the limit and discuss the implications of rewriting the expression. There is an acknowledgment of the indeterminate form and the need for careful manipulation to arrive at a conclusion.
courtrigrad
Hello all
I am having trouble proving the limit of the following:
lim sqrt(( n+1) - sqrt(n)) * sqrt(n+ 1/2 ) = 1/2
n --> 00
I tried using the fact the the limit of the first factor as n approaches infinity is 0. Then I tried expressing the first factor as
1 / sqrt(n+1) + sqrt(n) and doing the same thing for the other
factor. However I always get stuck.
Any help would be greatly appreciated!
As you have written the expression the limit does not exist. I suspect you meant something else.
lim (sqrt( n+1) - sqrt(n)) * sqrt(n+ 1/2 ) = 1/2
n --> 00
I trhink so:
=lim (sqrt( n+1) - sqrt(n)) *(sqrt( n+1) + sqrt(n)) * sqrt(n+ 1/2 ) /(sqrt( n+1) + sqrt(n)) = lim sqrt(n+ 1/2 )/(sqrt( n+1) + sqrt(n))=1/2
n --> 00
[tex]\lim_{n\rightarrow \infty} (\sqrt{n+1} - \sqrt{n}) \sqrt{n+\frac{1}{2}}=[/tex]
[tex]\lim_{n\rightarrow \infty} \frac{((n+1)-n)\sqrt{n+\frac{1}{2}}}{\sqrt{n+1}+\sqrt{n}}=[/tex]
[tex]\lim_{n\rightarrow \infty} \frac{\sqrt{n+\frac{1}{2}}}{\sqrt{n+1}+\sqrt{n}}=[/tex]
Now
[tex]2 \sqrt{n+1} > \sqrt{n+1} + \sqrt{n} > 2 \sqrt{n}[/tex]
so
[tex]\frac{\sqrt{n+\frac{1}{2}}}{2\sqrt{n+1}} < \frac{\sqrt{n+\frac{1}{2}}}{\sqrt{n+1}+\sqrt{n}} <<br /> \frac{\sqrt{n+\frac{1}{2}}}{2\sqrt{n}}[/tex]
so
[tex]\lim_{n\rightarrow \infty} \frac{\sqrt{n+\frac{1}{2}}}{2\sqrt{n+1}} \leq \lim_{n\rightarrow \infty} \frac{\sqrt{n+\frac{1}{2}}}{\sqrt{n+1}+\sqrt{n}} \leq \frac{1}{2}\lim_{n\rightarrow \infty}\frac{\sqrt{n+\frac{1}{2}}}{2\sqrt{n}}[/tex]
so
[tex]\lim_{n\rightarrow \infty} \frac{1}{2}\sqrt{\frac{n+\frac{1}{2}}{n+1}} \leq \lim_{n\rightarrow \infty}\frac{\sqrt{n+\frac{1}{2}}}{\sqrt{n+1}+\sqrt{n}} \leq \frac{1}{2}\lim_{n\rightarrow \infty}\sqrt{\frac{n+\frac{1}{2}}{n}}[/tex]
[tex]\frac{1}{2}\lim_{n\rightarrow \infty} \sqrt{1 - \frac{\frac{1}{2}}{n+1}} \leq \lim_{n\rightarrow \infty} \frac{1}{2} \frac{\sqrt{n+\frac{1}{2}}}{\sqrt{n+1}+\sqrt{n}} \leq\lim_{n\rightarrow \infty} \frac{1}{2}\sqrt{1 + \frac{\frac{1}{2}}{n}}[/tex]
But now the limits on the RHS and LHS are pretty obviously 1 so we have:
[tex]\frac{1}{2} \leq \lim_{n\rightarrow \infty}\frac{\sqrt{n+\frac{1}{2}}}{\sqrt{n+1}+\sqrt{n}} \leq \frac{1}{2}[/tex]
so the limit is [tex]\frac{1}{2}[/tex]
Thanks a lot for the very elegant solution!
Actually I'd just stop there (I'm not saying Nate's solution is large or anything but here's another way to "see" where the limit is going). I'd then divide the numerator and the denominator by the square root of n to get
[tex]\lim_{n\rightarrow \infty} \frac{\sqrt{n+\frac{1}{2}}}{\sqrt{n+1}+\sqrt{n}} = \lim_{n\rightarrow \infty} \frac{\sqrt{1+\frac{1}{2n}}}{\sqrt{1+\frac{1}{n}}+1}[/tex]
Taking limits gives (1/2) as the answer. You can recognize the original limit as an indeterminate form and divide by the arbitrarily growing variable n to get to the same thing.
I should mention however, that the sandwiching approach used by NateTG is far more elegant than this "trick" here (which gives you the answer but not an insight).
Cheers
Vivek
