Reacting CO2 with CaO and Boric Oxide
  • Thread starter Thread starter dg_5021
    Co2
The discussion revolves around the reactions of carbon dioxide (CO2) with calcium oxide (CaO) and boric oxide (B2O3). Participants explore whether boric oxide would react with CO2 in a manner similar to CaO, considering the chemical properties and classifications of boric oxide.
  • One participant states that reacting CO2 with CaO produces CaCO3 and questions if a similar reaction occurs with boric oxide.
  • Another participant suggests that boric oxide may be amphoteric, which could imply a potential reaction, but expresses doubt if it is solely an acidic oxide.
  • A participant inquires if the product of the reaction would be B2CO4.
  • It is mentioned that boric oxide is acidic, leading to skepticism about any reaction occurring, and if it did, the product would likely decompose back to boric oxide and CO2.
  • One participant introduces boric acid (H3BO3) and borax (Na2B4O7), suggesting that a reaction with CO2 might yield sodium carbonate, indicating a different reaction pathway.
  • A participant questions whether no reaction would occur at all.
  • Another participant references Lux's Acid and Base concept, positing that CO2 acts as an acid while boric oxide is also acidic, which raises doubts about the likelihood of a reaction.
  • One participant provides a material overview of boron, noting its amphoteric nature but questioning if this applies to boric oxide specifically.
  • A final participant comments on the drastic changes in elemental properties when forming compounds, using water as an example to illustrate the complexity of predicting reactions.
Participants express differing views on whether boric oxide will react with CO2, with some suggesting potential reactions and others doubting any reaction will occur. The discussion remains unresolved with multiple competing perspectives.
There are limitations regarding the definitions and classifications of boric oxide, as well as the assumptions about its reactivity with CO2. The discussion does not resolve the uncertainty around these aspects.
dg_5021
When I react CO2 with CaO I get CaCO3. If I react boric oxide with CO2 would it react similarly like the other one?
Chemistry news on Phys.org
Boric oxide (B2O3) may be amphoteric. If it is, then you might expect a similar reaction ...but if it's only an acidic oxide, I doubt that you'll have a reaction.
I'm probably wrong on this...let's wait for the experts to come along...
so would I get B2CO4?
Boric oxide's acidic, so you aren't likely to get any reaction, and even if you did the product would be unstable and would easily decompose back to boric oxide and carbon dioxide.
Pyrovus is right. I have no knowledge on boric oxide , but the nearest compound is boric acid, [itex]\displaystyle H_3BO_3[/itex], or better written as [itex]\displaystyle B(OH)_3[/itex]. However, borax, [itex]\displaystyle Na_2B_4O_7[/itex] is a cage-framework polyboric oxide. If you react this one with carbon dioxide, sodium carbonate will probably formed, resulting a cleavage inside the cage.
so i wouldn't get similar react I would just get no reaction?
You'd better look up Lux' Acid and Base concept; non protonic compounds (very generally, oxides) can behave acid or base according to some rules. In here, I presume that carbon dioxide is the acid, and boric oxide is also acidic; that's why I am doubtful about any reaction, like Gokul.
Gokul43201 said:
Boric oxide (B2O3) may be amphoteric...
Boron is amphoteric:
"MATERIAL OVERVIEW
"Characteristics: Nonmetallic element, black, hard solid; brown, amorphous powder; crystals. Highly reactive. Soluble in concentrated nitric acid and sulfuric acid; insoluble in water, alcohol, and ether. High neutron absorption capacity. Low toxicity. Amphoteric..."
http://www.espimetals.com/metals/catboron.htm
However, I don't think that necessarily means that PARTICULAR oxide will form both acids and bases.
In building up a compound, elemental properties drastically change. So we cannot devise a logic from there. Look at the example of water; hydrogen is a flammable gas, oxygen is a ignitor gas; water is a extinguisher.
  • · Replies 17 ·
