Why and How, are Computer speeds measured in Hertz?
  • Thread starter Thread starter Newtons Apple
    Computer Hertz
The discussion revolves around the measurement of computer speeds in Hertz, specifically focusing on CPUs, buses, and RAM. Participants explore the concept of clock cycles, the role of clock frequency, and how these relate to the operation of computer components.
  • One participant questions why computer speeds are measured in Hertz, noting that Hertz typically describes something that is "waving" or counting, and seeks clarification on what is "cycling" in a CPU.
  • Another participant explains that the 3.2 GHz speed refers to the clock input to the CPU, which controls the timing of the gates inside the CPU and allows for the changing of states.
  • There is a discussion about how clock frequency is generated through a clock generator, which is then multiplied to achieve a higher frequency output.
  • A participant speculates whether the clock can operate at a faster speed than the CPU itself and suggests that the clock provides a unifying tempo for the motherboard.
  • Another participant confirms that overclocking is a technique used to increase the CPU's speed beyond its rated clock speed, mentioning the potential risks and limitations associated with this practice.
Participants express varying levels of understanding about the relationship between clock speed and CPU operation, with some seeking clarification while others provide technical explanations. The discussion remains unresolved regarding the implications of clock speed and overclocking.
There are assumptions about the definitions of clock cycles and the mechanisms of clock generation that are not fully explored. The discussion does not resolve the complexities of how different components interact with clock signals.
Newtons Apple
Hey everyone. I'm beginning my exciting yet very nerve wracking road to a BS in computer science. I'm attending a university in NJ and hope to do well here. I love communications, networking, and all that jazz. Any who, one question has been bothering me. In my studying of computers, and how they work, I've run into one question that has been bothering me.
Why are computer speeds, (cpu, buses, and RAM) all measured in Hertz? To me Hertz describes something that's frequently 'waving' or counting. For example you can measure radio and gamma waves in hertz, because there's something moving in a frequent manner. But what's moving in a cpu that would allow it to be measured in hertz? When people refer to a CPU as having a 3.2 GHZ speed. It means that the processor is sending out info at 3 billion clock cycles.. But it just brings up the question, what is cycling? how long is a cycle measured?
The speed aspect of this is a bit confusing to me and I'd appreciate your discussion! I hope to hang out here on these forums, and gather as much information as possible, so excuse the elementary questions..
Computer science news on Phys.org
Newtons Apple said:
When people refer to a CPU as having a 3.2 GHZ speed, it means that the processor is sending out info at 3 billion clock cycles.
That 3.2 ghz speed is the clock input to the cpu (there could be a slower clock and clock multiplier in the cpu). The clock controls the timing of the gates inside the cpu, (the rate at which the gates can change states with some margin for transition and stabilizing time).
How the clock frequency is generated is through a very accurate clock generator, like a crystal, that then goes through a frequency multiplier that oscillates as some multiple of the clock generator input. The multiplier on it's own isn't that accurate, but is "tuned" at startup (or installation) to sync up with the slower but very accurate clock generator to end up with an accurate high frequency clock output.
hmm I think I get it... So the clock sets the tempo for all the chips on the board? Would that mean that the clock can beat at a faster speed than the CPU itself?
So the clock sends a unifying tempo to the entire mother board,telling everyone to beat at, let's say, 2.8 MHZ... then the CPU multiplies that so it can move a bit faster?
So each time the CPU and all the other chips send out and receive information, that counts as a cycle?
Indeed. Overclocking is the technique of speeding up the rate of the CPU.
Here's a primer: http://en.wikipedia.org/wiki/Overclocking
Chips can operate a lot faster than their rated clock speed, but start to get flaky. Manufacturers set the clock rate low enough to ensure no failures.
Your 3Ghz processor might be sped up to 4 or 5Ghz with no problem, but manus can't do this when they make them in bulk. Also, it will heat up a LOT more, and live a shorter life.
  • · Replies 29 ·
  • · Replies 58 ·
  • · Replies 87 ·
11K
