Thread Closed
newtons method
Share Thread Thread Tools
Nov12-04, 03:22 PM   #1
Exclamation
newtons method
i have the answer to this problem i just see why i'm not getting the same answer as my solution manuel. i Have two functtions f(x) = x and g(x) = tan(x)
and i have to find where these two functions are equal using newtons method.
i subtracted the two functions to get this new function H(x) = x -tan(x) then i found the differential of this new function to be 1 - sec^2 (x). now by looking at the given graph of the first two functions i estimated the soulution to be about 4.1. then by unising newtons method i calculated two iterations and got an answer of 8.5987, which is wrong the answer is 4.493. what could i be doing wrong? i know how to use newtons method.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Nov12-04, 03:43 PM   #2
You need to use a better first approximation.
Nov12-04, 04:50 PM   #3
Recognitions:
Homework Helper Homework Help
Quote by RadiationX
Are you sure that the two functions are only equal in one place? x and tan x intersect in *lots* of places.
Nov12-04, 05:30 PM   #4
newtons method
x has to be between pi/2 and 3pi/2 these are the asmyspotes.
Nov13-04, 05:02 PM   #5
Recognitions:
Gold Membership Gold Member
Quote by Muzza
You need a real good first approximation, otherwise it never converges. If you know that the tangent of 3 pi/2 is undefined and start a little lower than that, you're okay. If your guess is less than around 4.29, you won't converge.
Nov13-04, 09:07 PM   #6
thanks guys the last reply helped me out.
Thread Closed
Thread Tools
Similar Threads for: newtons method
Thread Forum Replies
shell method versus disk method Calculus & Beyond Homework 1
newtons method Calculus & Beyond Homework 3
work energy method and impulse momentum method Classical Physics 1
Weight/Newtons/unknown method Introductory Physics Homework 3
washer method and disc method for finding volumes of graphs Calculus 5
