Solve for x- the inequality of quadratic
The discussion revolves around solving the inequality \(\frac{2x}{x^2-9}\le\frac{1}{x+2}\), which involves quadratic expressions and rational functions. Participants are exploring the implications of the inequality and the conditions under which it holds.
  • Mixed
  • Some participants attempt to manipulate the inequality by converting it into a single expression, while others question the validity of the steps taken, particularly regarding the implications of multiplying by expressions that may be negative.
There is an ongoing exploration of different methods to approach the problem, with some participants suggesting alternative ways to handle the inequality. Questions about assumptions regarding the values of \(x\) that make the denominators zero are also being raised.
Participants note the restrictions on \(x\) due to the denominators \(x^2-9\) and \(x+2\) not being zero, leading to specific values being excluded from consideration in the solution.
Sumedh
Solve for x-- the inequality of quadratic
Solve [tex]\frac{2x}{x^2-9}\le\frac{1}{x+2}[/tex]
[tex]x^2-9\not=0[/tex]
.'. [tex]x\in R-\{-3,3\}[/tex]
and
[tex]x+2\not=0[/tex]
.'. [tex]x\in R-\{-2\}[/tex]
then converting the original inequality to
[tex](2x)(x+2)\le(x^2-9)[/tex]
[tex](2x^2+4x)(-x^2+9)\le 0[/tex]
[tex](x^2+4x+9)\le 0[/tex]
As Discriminant <0 it has no real roots
so how to do further...
My assumptions:-
[tex]x^2-9[/tex]should not be zero
[tex]x+2[/tex]should also not be zero
Are my assumptions right?
Any help will be highly appreciated.
I see what you did here, but it's not correct. It's not true that
[tex]\frac{a}{b}\leq \frac{c}{d}[/tex]
implies that [itex]ad\leq bc[/itex]. For example
[tex]\frac{1}{-1}\leq \frac{1}{1}[/tex]
but it's not true that [itex]1\leq -1[/itex]. The problem is of course that negative numbers reverse the inequality sign.
How do we do such a thing then?? Well, first we move everything to the left side of the equation:
[tex]\frac{2x}{x^2-9}-\frac{1}{x+2}\leq 0[/tex]
and now you must try to add these fractions.
and
My assumptions:-
In general, if a <= b we have a*c <= b*c if c > 0 and a*c >= b*c if c < 0. Thus, if x+1 > 0 you have 2x(x+2)/(x^2-9) <= 1 and if x+2 < 0 you have the opposite inequality. Now, in each case, look at whether x^2-9 is positive or negative.
RGV
I often prefer to multiply by a square to avoid splitting into too many +/- cases. It's a compromise though, between getting a higher order system versus less case splitting.
[tex]\frac{2x (x+2)^2}{x^2-9}\le x+2[/tex]
I'll split into cases for the (x^2-9) factor to keep the order of the system under control.
[tex]2x (x+2)^2 \le (x+2) (x^2-9)\,\,\,\, : \,\, |x|>3[/tex]
[tex]2x (x+2)^2 \ge (x+2) (x^2-9)\,\,\,\, : \,\, |x|<3[/tex]
Now we've got a cubic, but one factor is already out, so rearrange without re-absorbing the "outed" factor.
[tex](x^2 + 4x + 9)(x+2) \le 0\,\,\,\, : \,\, |x|>3[/tex]
[tex](x^2 + 4x + 9)(x+2) \ge 0\,\,\,\, : \,\, |x|<3[/tex]
Here we have a cubic with just one real root at x=-2, so it's pretty easy to deduce where it's greater or less than zero. Just combine those regions (intersection) with the |x|>3 and |x|<3 constraints and make sure you omit the singular points that weren't in the original domain (-2).
Thank you very much.
