Solve for x using basic algebraic equations: 2x-x^2=3
  • Thread starter Thread starter davie08
The problem involves solving the equation 2x - x² = 3, which falls under the subject area of algebra, specifically quadratic equations. Participants are discussing methods to manipulate the equation and explore potential solutions.
  • Exploratory, Problem interpretation, Assumption checking
  • Some participants suggest rearranging the equation to set it to zero, while others consider using the quadratic formula or factoring. There are questions about the correctness of initial steps and the implications of negative values under a square root.
The discussion is ongoing, with participants exploring different methods to approach the problem. Some guidance has been offered regarding the rearrangement of the equation and the use of the quadratic formula, but there is no consensus on the final outcome or solutions.
Participants express stress over managing multiple math problems and the constraints of time, which may affect their engagement with the problem. There is also mention of the distinction between quadratic and cubic equations, indicating a broader context of algebraic problem-solving.
davie08
solve for x: 2x-x^2=3
2x-x^2=3
do i go -x^2=3-2x
thats not right i can tell but i got a warning for not showing work and for this question again i don't know where to start but maybe if i throw a guess in this will satisfy the guy who watches for this.
actually this is too much of a hassle since I am doing so many questions in such a short time period i will be back in another week when i start my actual math course sorry mark I am just stressed over doing 8 hours of math everyday.
make the equation = 0
then either use the quadratic formula or factorising to solve for x
2x-x^2=3
do i go -x^2=3-2x
Move all of the terms over to one side, so that zero is on the other side. Starting from your first equation,
2x-x^2=3
rewrite this as
-x^2 + 2x - 3 = 0
You can make the x^2 coefficient positive by multiplying both sides by -1.
okay I think I will just learn the quad formula for this so with making the x^2 positive would I make the 2x negative and the -3 positive.
I end up with a -8 in a square root when I use the quad formula what would I do from there or did I screw up somewhere.
yep there should be a negative number in the square root, which means there are no x solutions
ie. the graph of the function does not cross the x axis.
so no real solutions of course there are 'imaginery' solutions
could I use the quad. formula for a question like 0=125+27k^3
no the quardratic formula is for something to the power of 2 not 3 or more
there is a forumula for the power of 3 but it's quite complicated. It is easier to factor out something to end up with a power of 2.
in this case you can factor out 3x+5
for 0= 125+27k^3 would the answer be k=5/3
The formula for factoring the sum of cubes (a^3+b^3) is (a+b)(a^2-2ab+b^2)
so, (5+3k)(25-30k+9k^2)=0
so one solution is found by 5+3k=0
and another by 25-30k+9k^2=0
The simplest way to solve [itex]125- 27k^3= 0[/itex] is to write it as [itex]27k^3= 125[/itex], divide both sides by 27, and take the cube root of each side. As AracnNoir points out, there are two other solutions (the roots of his [itex]25- 30k+ 9k^2= 0[/tex] but they are both complex numbers.<br /> <br /> Yes, [itex]125= 5^3[/itex] and [itex]27= 3^3[/itex] so 5/3 is an answer. You could have checked that yourself- if x= 5/3, then [itex]x^3= 5^3/3^3= 125/27[/itex] so 27x^3= 27(125/27)= 125.[/itex]
  • · Replies 24 ·
  • · Replies 25 ·
