Finite Math Help: Ratio of A to B for 100% Nutrition
  • Thread starter Thread starter demongrl2204
    Finite
The problem involves determining the appropriate amounts of two substances, A and B, to meet a patient's nutritional needs based on given ratios and nutritional contributions. It is situated within the context of finite mathematics, specifically focusing on ratios and systems of equations.
  • Exploratory, Problem interpretation, Assumption checking
  • The original poster seeks guidance on how to set up the problem related to ratios, expressing confusion about the information provided. Some participants suggest establishing a system of equations based on the nutritional contributions and the specified ratio of substances A and B.
Participants are actively discussing how to formulate the problem into equations. There is an acknowledgment of the need for two equations: one for total nutrition and another for the ratio of A to B. The original poster is encouraged to clarify their understanding of these relationships.
The original poster notes a feeling of insufficient information to solve the problem, particularly regarding the application of the 3/5 ratio in the context of the problem.
demongrl2204
finite math help??
Just need a clue of how to start this problem (kinda confused with the ratios)
I know what the answer is, (from back of book)just need to know how to set it up in order to do other problems??
**Each ounce of substance A supplies 5% of the nutrition a patient needs. Substance B supplies 12% of the required nutrition per ounce. If digestive restrictions require that the ratio of substance A to Substance B be 3/5, how many ounces of each should be in the diet to provide 100% of the required nutrition??**
thanks for any help!??
Welcome to PF!
Try set up a system of equations:
Let "x" be the number of ounces of "A", "y" the number of ounces of B.
What relations between "x" and "y" have you been given?
I understand how to do the equation type problems, but this one just didn;t make sense to me, cause that's all the information it gives and i seems like it isn't enough or you have to do something with the 3/5 ration btw A and B and I don't understand how to do that??
You should be able to get two equations out of the problem, one involving the total amount of nutrition consumed, the other involving the ratio bit you are having trouble with.
The ratio of substance A to substance B is the number of ounces of A divided by the number of ounces of B, e.g. if you had 10 ounces of A and 3 ounces of B this would be 10/3. The requirement that this ratio is 3/5 gives you your second equation.
Can you set up these two equations? What do you get?
