What is the magnitude of angular acceleration upon release?
The problem involves a dumbbell consisting of a slender rod and two spheres of different masses, pivoted at its center. The question focuses on determining the magnitude of angular acceleration immediately after the dumbbell is released from a horizontal position.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the calculation of torque and angular acceleration, questioning the definition and value of the moment of inertia (I) given the negligible mass of the rod and the treatment of the spheres as point masses. There is also a consideration of the center of mass in relation to torque calculations.
Some participants have provided guidance on treating the spheres as point masses and have engaged in calculations related to angular acceleration. However, there remains uncertainty about the implications of the center of mass on the calculations and whether the derived value is correct.
Participants are working under the assumption that the rod's mass is negligible and are exploring the implications of this on the moment of inertia. There is also a lack of clarity regarding the radius of the spheres and its effect on the calculations.
justagirl
A dumbbell consists of a slender rod of negligible mass and small spheres attached to each end with mass 12-kg and 6-kg respectively. It is pivoted at its center about a fixed horizontal frictionless axle and initially held in place horizontally. The length of the rod is 50 centimeters and connects the centers of the two spheres. The dumbell is then released.
What is the magnitude of angular acceleration immediately upon release?
I wrote down torque = I(alpha)
alpha = torque / I = 12(0.5) - 6(0.5) / I
I am stuck here. And what would "I" be in this case since the rod is neglible mass and we don't know the radius of the spheres?
Thanks!
Treat the spheres as point masses. What's the rotational inertia of a point mass fixed a certain distance from an axis?
Okay... treating them as point masses:
alpha = torque / I
= (m1)gr - (m2)gr / m1(r^2) + m2(r^2)
= 12(9.8)(0.25) - 6(9.8)(0.25) / ((.25^2) (m1 + m2))
= 13.1
Is that right? So the position of the center of mass doesn't really matter in this case?
Thanks!
justagirl said:
= 13.1
Is that right?
Yes, in units of radians/sec^2.
I'm not sure what you mean. If you had wished, you could have calculated the torque by considering the mass as concentrated at the center of mass.
  • · Replies 33 ·
  • · Replies 18 ·
  • · Replies 62 ·
14K
