| New Reply |
Finding Node Voltages Using the Node Method |
Share Thread |
| Aug31-11, 08:20 PM | #1 |
Find the node voltages for the circuit shown. 2. Relevant equations See attachment. 3. The attempt at a solution I have chosen my ground node as the set of nodes in the bottom of the image and labeled all of my unknown voltages as en. Here is what I have so far. Where G = 1/R For the node labeled e1: (e1-v0)G1 + e1(G3) + (e1-e2)I1 + (e1-e2)G2=0 For the node labeled e2: (e2-e1)(-I2) + e2(G4) + (e2-e1)G2=0 I am pretty sure my problem lies in the way I am handling the currents in the node. I started plugging in numbers after I simplified it all and one of my unknown voltages went away. After that I looked at it again and knew I was doing it wrong. Most of the examples in the book don't deal with a current parallel to a resistor. I think the way I should have done it is rather than subtracting voltages and multiplying like I am doing with the resistor nodes, is just take the current by itself. So in my above equation e1)(-I1) would just become -I1 since I am not using ohms law for current. I think I only need current? Does that sound better? |
| Aug31-11, 10:23 PM | #2 |
Recognitions:
| Sep1-11, 01:26 PM | #3 |
Perfect! Thanks for the help.
It seems half the time I post problems, I get them mostly figured out just typing the post up. :) |
| Sep1-11, 02:51 PM | #4 |
Recognitions:
| New Reply |
Similar discussions for: Finding Node Voltages Using the Node Method
| What is a radial Node ? What is an Angular Node ? | Chemistry | 6 | ||
| EE, Node voltages, can't figure out how to reach end result | Engineering, Comp Sci, & Technology Homework | 2 | ||
| How do I know when to use the Mesh Current Method or Node Voltage Method? | Electrical Engineering | 1 | ||
| CIRCUIT ANALYSIS: 4 resistor, Current src, Voltage src, V.C.V.S. - Find node Voltages | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Node method again... | Engineering, Comp Sci, & Technology Homework | 9 | ||
