Checking if One Array is Contained in Another using Java Arrays
  • Context: Java
  • Thread starter Thread starter courtrigrad
    Arrays Java
The discussion revolves around writing a Java program to determine if one array is contained within another. Participants explore various interpretations of "containment," including whether it refers to having the same elements regardless of order or requiring a specific order of elements.
  • Homework-related
  • One participant seeks advice on how to check if one array is contained in another, providing examples.
  • Another participant questions the definition of "contains," asking if it refers to having the same elements or being a sublist.
  • Some participants clarify that "contains" can mean having any of the elements, not necessarily in order.
  • There is a suggestion to consider how to approach the problem manually, especially with larger arrays.
  • Participants discuss the need for a clear algorithm and mention different algorithmic complexities, including O(mn) and O(n) algorithms.
  • One participant proposes a basic algorithm involving looping through the arrays to check for matches.
  • Another participant suggests that the problem resembles finding a substring within a string, which may involve different complexities based on order and duplicates.
  • There are discussions about Java syntax, particularly regarding array access methods and variable declarations.
  • Several participants provide code snippets and critique each other's approaches, addressing issues like variable definitions and method calls.
Participants express differing views on whether order matters in determining if one array is contained in another. Some agree that order is significant, while others suggest it may not be. The discussion remains unresolved regarding the specifics of the implementation and the definition of containment.
Participants mention various algorithmic approaches without reaching a consensus on the best method. There are also unresolved questions regarding Java syntax and array handling.
This discussion may be useful for individuals learning Java programming, particularly those interested in algorithms related to array manipulation and containment checks.
courtrigrad
Hello all
I am trying to write a program that checks whether one array is contained in another array. For example,
A = {1,2,3}
B= {1,2,3,4,5,6}
A is contained in B, so we print out true, otherwise we print out false.
Any advice or tips in writing this program would be greatly appreciated.
Thanks!
Technology news on Phys.org
When you say "contains" do you mean simply that one array has the elements of the other? (e.g. {1, 2, 4} contains {4, 2}), or are you specifically requiring one to be a sublist of the other? (e.g. {1, 2, 3, 4} contains {1, 2, 3} but not {1, 3} or {3, 2, 1})
No i mean that it can contain any of the elements:
This is correct
Any help would be greatly appreciated
Thanks a a lot!
(does {1, 2, 4} contain {4, 2, 2}?)
Well, how would you do this by hand? And I don't mean on an easy example like this -- what if you had two arrays each with hundreds of elements! How would you do such a problem by hand?
Actually, let's say we have
A = {1,2,3,4} and B = {1,2,3,4,5}
Then B contains A. In order for B to contain A all of the elements of A have to be in B in the exact same order.
Same question: suppose the arrays were hundreds long. How would you do it by hand?
wouldnt you check whether the first n-1 elements of each array match each other?
Well, does {1, 2, 3, ..., 1000} contain {1, 2, 3}? What about {10, 11, 12}?
yes, so would you loop through each array, and see whether an elements match. How would you do this?
You first figure out how to write clear, precise algorithm. It may seem laborious, but you have to do it anyways to write your program, so you might as well do it in a language you understand better.
Here is what I did:
First I need to declare the two arrays A and B.
Then I write elements (integers) in the two array A and B.
Go through all the elements of arrays A and B.
If successive locations in the array have the same element return true. Print true.
If not return false.
Then print false.
Would this be the basic algorithm in trying to write this program?
What you are trying to do is find a substring within a string. There are a couple algorithms that can accomplish this.
There is an very easy, two loop, O(mn) algorithm that can do it (where m,n are the size of your arrays).
There is a smarter algorithm that skips ahead in the loop giving you better running time.
There is a O(n) worst case algorithm that requires the use of trees.
what do you mean by an O(mn) algorithm? I am just learning ( in middle school). Can you please be more specific?
Thanks
Thanks
Oh, well in that case don't worry about O(n) stuff yet, unless you have at least algebra behind you.
I just realized that the problem is a little bit different than substring within a string. That is actually harder to do. Given your example, order and duplicates do not matter. In other words if { 1, 2, 3} contains {2, 3, 2, 3} ? This is quite easy to do:
for each element in B
scan to see if the element is in A
Write the code in your language of choice and I'll critique it.
Okay, it seems that I'm confused on the specifics... Does order matter? If so, it's really easy. If not, it's not so easy, but still easy.
Hint, just in case you need it: Java arrays can tell you how long they are.
if you have an array a = {1,2,3,4}, you can see how long it is by saying a.length. You may or may not need this, depending on the specifics of the assignment.
You will definitely need at least one "for" loop, though.
Code:
 boolean exsist = false;
for(i=0;i<a.length;i++)  //loop through your a array
  exsist = false; //set the flag equal to false. Do it hear because we want to see if that particular element is in the 2nd array
   for(j=0;j<b.length;j++)
    if( a.get(i) == b.get(j) )
      //if a is in b then set to true and break out of the loop cause no reason to finish
      exsist = true;
      break;
   } //end 2nd array for
  if(exsist == false)
   if we get hear that means the previuos element wasn't in the array, so the hole thing sucks and it's a bust. so might as well break out of the loop
   break;
if(exsist == true)
system.out.print(" all of A's elements are in array B");
Looks like it would work to me.
Why isn't my code working? It says variable i is not defined.
Code:
 public class check
    public boolean isDifferent(int [] a, int [] b)
    for(i=0; i < a.length; i++)  //loop through your a array
    exsist = false;
      exsist = true;
      break;
  if(exsist == false)
   break;
if(exsist == true)
You need to define a datatype for 'i'. Decide whether it is an integer, double, float, string, etc and declare it.
what about a.length? Why does it say its not defined?
It should be a.length() (similarly, b.length()).
Let me ask something. I didn't know that we can write a.get( index ). Doesn't Java allow the use of a[ index ]?
I didn't know about being able to write a.get(index) either, but yes, Java does allow you to use a[index] if you want the value stored at that index position.
  • · Replies 17 ·
  • · Replies 25 ·
15K
