Proving the Limit of a Sequence: A Formal Proof Refuting an Informal Claim
  • Context: Graduate
  • Thread starter Thread starter evagelos
The discussion revolves around the formal proof of the limit of the sequence \(\lim_{n\rightarrow\infty} \frac{1}{n}\) and the refutation of an informal proof claiming that this limit equals 1. Participants analyze the structure of the informal proof and identify flaws in its reasoning.
  • Some participants argue that the informal proof incorrectly assumes a consequence of the statement being proven, specifically in Step 2.
  • Others suggest that a contradiction proof should only assume the limit equals 1 without using known results about the limit being 0.
  • A participant proposes a direct proof using a specific value for \(\epsilon\) to demonstrate the limit's behavior.
  • There is a discussion about the nature of limits, with some emphasizing that both \(\lim_{x \to a} f(x) = 0\) and \(\lim_{x \to a} f(x) = 1\) cannot simultaneously hold.
  • Some participants highlight the need for clarity on whether \(\lim_{n \rightarrow \infty} \frac{1}{n} = 0\) is an established theorem or not.
  • There are differing opinions on the necessity of finding a formal proof versus simply identifying flaws in the informal proof.
  • Participants discuss the distinction between writing a formal proof and finding alternative solutions, with some asserting that a formal proof expands on existing arguments rather than presenting new ones.
Participants generally disagree on the validity of the informal proof and the correct approach to proving the limit. Multiple competing views remain regarding the structure and assumptions of the proof.
There is uncertainty regarding the status of the limit \(\lim_{n \rightarrow \infty} \frac{1}{n} = 0\) as a previously established result, which affects the arguments made in the discussion.
evagelos
formal vs informal
in proving that: [itex]lim_{n\rightarrow\infty} \frac{1}{n}\neq 1[/itex] the following proof was suggested.
Proof:
Suppose [itex]lim_{n\rightarrow\infty}\frac{1}{n} =1[/itex], but [itex]lim_{n\rightarrow\infty}\frac{1}{n} =0[/itex], hence:
For all ε>0
1) There exists mεN such that: [itex]n\geq m\Longrightarrow |\frac{1}{n}|<\frac{\epsilon}{2}[/itex]
2)There exists kεN such that : [itex]n\geq k\Longrightarrow |\frac{1}{n}-1|<\frac{\epsilon}{2}[/itex]
Choose r = max{m,k},then [itex]r\geq m,r\geq k[/itex]
Let ,[itex]n\geq r\Longrightarrow n\geq m\wedge n\geq k[/itex].
Hence : [itex]|\frac{1}{n}|<\frac{\epsilon}{2}[/itex] and [itex]|\frac{1}{n}-1|<\frac{\epsilon}{2}[/itex].
Thus : [itex]|\frac{1}{n}-\frac{1}{n}+1|=1\leq |\frac{1}{n}| + |\frac{1}{n}-1|<\frac{\epsilon}{2}+\frac{\epsilon}{2}=\epsilon[/itex]
.....or 1<ε...But since this holds for all ε>0 we put ε=1 and we have 1<1 ,a contradiction .
Therefor [itex]lim_{n\rightarrow\infty}\frac{1}{n}\neq 1[/itex]
Write a formal proof of the above ,thus proving that the above informal proof is wrong
Step 2) is wrong!
The proof is flawed at this point. If you're going to use a contradiction proof, you can't assume a consequence of what you're trying to prove and the contradictory statement at the same time. If you're going to prove by contradiction, only assume [itex]lim_{n\rightarrow\infty}\frac{1}{n} =1[/itex] and obtain a contradiction from that(using limit definition).
mathman said:
Step 2) is wrong!
I suppose there is an explanation for that
I do not understand.We want to prove that: [itex]lim_{n\rightarrow\infty}\neq 1[/itex] and we assume the opposite i.e:[itex]lim_{n\rightarrow\infty}= 1[/itex] until we get a contradiction.Meanwhile we do know (we have proved that) [itex]lim_{n\rightarrow\infty}=0[/itex] and we use that in our proof.Where is the mistake
In logical terms we want to prove : q= ([itex]lim_{n\rightarrow\infty}\neq 1[/itex]) .We assume not q= ([itex]lim_{n\rightarrow\infty} = 1[/itex]) until we come to a contradiction:
s and not s.In our case s is: 1<1 and not s is: [itex]\neg 1<1[/itex] ,since we know that:
...[itex]\forall x(\neg x<x)[/itex].....
evagelos,
You aren't making it clear whether [itex]\lim_{n \rightarrow \infty} {\frac{1}{n}} = 0[/itex] is to be taken as a previously established theorem.
It would much simpler to write a direct proof anyway. Let [itex]\epsilon = \frac{1}{2}[/itex]. Let M be any nonnegative integer. Let K be the max of the set {3,M+1}. Then [itex]\frac{1}{2} < 1 - \frac{1}{3} \leq 1 - \frac{1}{K}[/itex]. So [itex]| 1 - \frac{1}{K} | \geq \epsilon[/itex].
Let me remind people a subtle point about the definition of limit: a priori, both of the following statements could be true:
  • [tex]\lim_{x \to a} f(x) = 0[/tex]
  • [tex]\lim_{x \to a} f(x) = 1[/tex]
If you're paying attention to the subtle details, one of the first thing you do with limits is prove that if
  • [tex]\lim_{x \to a} f(x) = L[/tex]
  • [tex]\lim_{x \to a} f(x) = M[/tex]
are both true, then L = M. (And only once we've done this step does it make sense to ask about "the value of the limit".
If I had to guess, evagelos is trying to replicate that argument in a special case, where he has a specific a, f, L=0, M=1, and wants to deduce that this leads to contradiction.
evagelos said:
...Suppose [itex]lim_{n\rightarrow\infty}\frac{1}{n} =1[/itex], but [itex]lim_{n\rightarrow\infty}\frac{1}{n} =0[/itex]...
Just change "but" to "but we already know that" and it's fine.
Stephen Tashi said:
evagelos,
Well.....
Any No ,k, greater than M i.e M+1,M+2,M+3.....e.t.c ,would make :
[itex]|1-\frac{1}{k}|>\frac{1}{2}>\epsilon>0[/itex] ,you do not have to take k as the max{3,M+1}
But the point is not finding other solutions .The point here is that the above suggested solution is wrong .
And i proposed that the only way to find that out is by writing a formal proof for the problem.
Unless somebody shows another way
We have limits of sequences here,which a completely different aspect of that concerning limits of functions
Suppse M = 1 then K = M+1 doesn't make [itex]|1 - \frac{1}{k}| > \frac{1}{2}[/itex]
Besides, a proof only has to pick a K that works. It doesn't have to pick the smallest K that works.
How do you distinguish between "writing a formal proof for the problem" and "finding other solutions"? If you write a formal proof for the problem, you are finding another solution to proving it.
Limits of sequences are limits of functions. But even if you don't want to think about that and want to imagine them different, everything I've said applies to both cases.
FOR M=1 we have M+1 =2 and [itex]|1-\frac{1}{2}|\geq\frac{1}{2}[/itex]
I forgot the equality
Definitely not . Formal proof is expanding on an already existing informal proof.
For example if we want to prove that : 0x =0,we can write the following informal proof:
1x = x => (1+0)x = x+0 => 1x +0x = x+0 => x+0x x+0 => 0x = 0
Now if we want to write a formal proof of the above informal proof we have to justify each statement of the proof .For example (1+0)x =x+0 , where did it come from ,what laws of logic on what theorems or axioms applied to give us the desired result?
WE do not write another proof.
Well, I'm glad that's settled. Now we can all go home.
good by
  • · Replies 29 ·
