Help in matlab image processing ?
The forum discussion centers on an issue with opening a TIFF image file named "manish.tiff" in MATLAB using the command rgb = imread('manish.tiff'). The user encounters an error stating that the file does not exist, while another TIFF file, "hurra.tiff," opens successfully. The recommended solution is to use the full path name in the imread command to avoid file location issues.
  • Familiarity with MATLAB programming environment
  • Understanding of image file formats, specifically TIFF
  • Knowledge of file path structures in operating systems
  • Basic troubleshooting skills in coding
  • Learn how to use absolute file paths in MATLAB
  • Explore MATLAB's imread function documentation for additional options
  • Investigate common image file format issues in MATLAB
  • Practice error handling in MATLAB for file operations
MATLAB users, image processing enthusiasts, and anyone troubleshooting file access issues in MATLAB.
munna007
Help in MATLAB image processing ?
hello friends...i save my picture named "manish.tiff" in MATLAB directory...then opening this with command named rgb =imread('manish.tiff') in command window...but it shows error...
below is the error i m getting.
(? Error using ==> imread
File "manish.tiff" does not exist. )
ut when i open this picture " hurra.tiff " with same command it opens succesfully...
i have tried a lot...but couldn't solve...
please help ...i have attached both the pictures in jpeg format...because tiff was not uploading here...
thanks...
It says the file doesn't exist, not that it is the wrong format. I would use the entire path name in the code.
10K
