Rule of correspondence question.
  • Thread starter Thread starter davie08
The rule of correspondence for the linear function f that passes through the points (3, -1) and (2, 3) is defined by the equation f(x) = -4x + 11. To derive this equation, one must first calculate the slope using the two given points. The point-slope form of a linear equation, y - y0 = m(x - x0), is then utilized to formulate the equation, confirming that either point can be used without affecting the outcome.
  • Understanding of linear functions and their properties
  • Knowledge of slope calculation between two points
  • Familiarity with point-slope form of a linear equation
  • Basic algebraic manipulation skills
  • Learn how to derive linear equations from two points using slope-intercept form
  • Explore the concept of slope and its geometric interpretation
  • Study the differences between point-slope form and slope-intercept form
  • Practice solving linear equations with various pairs of points
Students studying algebra, mathematics educators, and anyone seeking to understand linear functions and their graphical representations.
davie08
find a rule of correspondence for the linear function f whose graph contains the given points.
(3, -1) and (2, 3)
would you try to find the slope first and then after finding that I'm unsure of what to do.
the answer is f(x)= -4x + 11
There are several ways of determining the equation of a line. The method you choose depends on what information you have. In this case, you're given two points, so you could find the slope. Now the easiest way to find the equation is to use the point-slope form.
[tex]y-y_0 = m(x-x_0)[/tex]
Just choose one of the points to use as (x0, y0) and plug your slope in and simplify. You might want to try it with both points to see that it doesn't make a difference which one you choose.
thanks.
  • · Replies 19 ·
