New Reply
Frequency of oscillating electric dipole in uniform field without using diff eq
Share Thread
Sep10-11, 02:22 PM   #1
Electric dipole makes small angle with uniform electric field. Find the frequency of the oscillation using dipole moment p, moment of inertia I, and field magnitude E.
2. Relevant equations
Torque=I*(angular acceleration)=I*(theta)''
Torque=p*E*sin(theta)
3. The attempt at a solution
What I did was set PE*sin(theta)=I*(theta)'' But then I need to solve a differential equation which is absolutley not supposed to be required for this class.
Is there a way to find this frequency without solving a differential equation?
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Sep10-11, 02:32 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Retired Staff Staff Emeritus
You forgot a minus sign. When the angle is small, you can use the approximation [itex]\sin \theta \cong \theta[/itex], which gives you
[tex]I\ddot{\theta} = -pE\theta[/tex]
Now compare this to the equation of motion for a simple harmonic oscillator.
[tex]m\ddot{x} = -kx[/tex]
where the angular frequency is given by [itex]\omega =\sqrt{k/m}[/itex].
Sep10-11, 02:44 PM   #3
Aren't you technically solving a differential equation by telling me the angular frequency of a simple harmonic oscillator?
I was thinking of an approach where I would integrate torque over time (rather than angle) to get a change in angular momentum, then use that to determine at what point in its cycle the oscillator is, since when that change is zero (after a non-zero time), whatever time passed to reach zero angular momentum would be half the period. Is this feasible?
Thanks for your reply, btw.
Sep10-11, 02:56 PM   #4
Recognitions:
Perhaps. You could try it and see how it works out, but I think you'll run into a problem trying to integrate the righthand side of the equation since you don't know how θ varies as a function of time.
I think what's expected is that you're supposed to recognize the form of the resulting differential equation and from that deduce what the frequency and solutions are. You don't actually have to solve the equation, per se. You just essentially follow a recipe and write down what the answers should be.
New Reply
Similar discussions for: Frequency of oscillating electric dipole in uniform field without using diff eq
Thread Forum Replies
Angular acceleration of dipole in uniform electric field Introductory Physics Homework 3
Find frequency of oscillating electron in electric field Advanced Physics Homework 3
Dipole in an Uniform Electric Field concept? Introductory Physics Homework 3
Dipole in an Uniform Electric Field: Classical Physics 1
Non-uniform electric field and a dipole Advanced Physics Homework 18
