Does expanding space affect time dilation etc?
The discussion centers on the implications of expanding space on time dilation in the context of special relativity. It establishes that if two objects are stationary with respect to each other but separated by expanding space, the concept of time dilation becomes ambiguous. The participants conclude that without a well-defined inertial reference frame (IRF) encompassing both objects, traditional notions of time dilation do not apply. Instead, they suggest analyzing the situation through the lens of redshift and blueshift of light signals exchanged between the objects, where redshift occurs in the first scenario and no shift occurs in the second.
  • Understanding of special relativity concepts, including time dilation and length contraction.
  • Familiarity with inertial reference frames (IRFs) and their significance in relativity.
  • Basic knowledge of redshift and blueshift phenomena in astrophysics.
  • Awareness of the implications of expanding space in cosmology.
  • Study the principles of special relativity, focusing on time dilation and length contraction.
  • Explore the concept of inertial reference frames and their application in relativistic physics.
  • Investigate the mechanisms of redshift and blueshift, particularly in the context of cosmological expansion.
  • Examine the implications of expanding space on the fabric of spacetime and its effects on relativistic measurements.
Physicists, students of relativity, and anyone interested in the effects of expanding space on time and light phenomena.
Dizzle
In special relativity we have the velocity 'u', being the difference in speed between two objects, from which we work out time dilation, length contraction etc.
But if those objects are separated by some expanding space, but not moving with respect to that space, is there still the dilation effect?
What if both moved towards each other at the same speed as the space expanded between them, so the net effect what they weren't moving with respect to each other? Would there be no time dilation etc then?
For expanding space, I think you run into the issue that you cannot define a single IFR that encompasses both objects. That's why speeding tickets are not issued to galaxies which are receding from us at > c.
If they are stationary w/ respect to each other, I can't see how there would be an time dilation between them regardless of other circumstances, but in the absence of their being in the same IFR I'm not as sure about that.
This question isn't really answerable, because the concept of "time dilation" is not well-defined if "space" is expanding. ("Expanding space" isn't really the best description of what's going on, but going into that would probably be too much for this thread.)
Same answer as above.
You can make the questions well defined by considering, instead of "time dilation", something like the observed redshift/blueshift of light signals exchanged between the two objects. Then the answer would be that in the first case, each object would observe the other's light to be redshifted, and in the second case, each object would observe no redshift/blueshift in the other's light.
  • · Replies 27 ·
  • · Replies 16 ·
  • · Replies 63 ·
  • · Replies 16 ·
  • · Replies 37 ·
