Is the Higgs Field a New Perspective on Gravity Beyond General Relativity?
The discussion explores the relationship between the Higgs field and gravity, particularly in the context of General Relativity (GR) and quantum mechanics (QM). Participants examine whether the Higgs field offers an alternative perspective on gravity or if it complements the existing framework of GR.
  • One participant suggests that mass arises from the coupling of particles with the Higgs Boson, proposing that inertial mass is influenced by interactions with the Higgs field.
  • Another participant discusses spontaneous symmetry breaking and its implications for the Higgs field, indicating that it leads to mass terms in the equations, but expresses uncertainty about its relation to GR.
  • A participant reiterates the idea that the curvature of space-time in GR is unrelated to the Higgs field, indicating a perceived problem in reconciling the two concepts.
  • There is a speculative comparison made between Higgs particles and black holes in the context of Quantum Gravity.
  • One participant argues that the Higgs field and space curvature are not alternative descriptions, suggesting that gravity can be viewed as a reaction of space to matter, and that both the Higgs field and space curvature affect mass particles simultaneously.
Participants express differing views on the relationship between the Higgs field and the curvature of space in GR. Some propose that they are distinct concepts, while others suggest they may interact or complement each other. The discussion remains unresolved with multiple competing views present.
Participants express uncertainty about the implications of the Higgs field for gravity and the relationship between quantum mechanics and general relativity, indicating a need for further exploration of these concepts.
ohwilleke
Higgs hypothesized that mass derives from the coupling constant of various particles with the Higgs Boson, a spin zero boson, which would itself have mass, which does not couple with the photon. Thus, inertial mass derives from particles in motion needed to overcome Higgs Bosons grabbing at them slowing them down from the default rate of movement in the absence of these couplings which is c.
The proposed graviton, which would be a spin two Boson which interacts with photons, would then be a particle creating a force to drag other particles through the Higgs field just like any other force.
My questions: Is the Higgs field an alternative to the curvature of space description of gravity described by GR or in a QM interpretation with a Higgs Field and a Graviton does this apparent curvature derive from the field equations associated with the Graviton?
When symmetry is spontaneously broken, the vacuum state is not the lowest energy state. You "shift" the fields using a gauge transformation so that the new fields do have the vacuum state the lowest. This involves incorporating the Higgs field to achieve this. The new equations have a mass term appearing. i.e. the "shift" causes the energy to go from the vacuum to the particle. (my interpretation only.)
The curvature of space-time in GR is, as I understand, completely unrelated and therein lies the big problem. I wish I knew how to fix this "patch"!
Higgs particles can be like black holes in Quantum Gravity - no?
Can't you just see it at the LHC?
Oooooh - nice little black holes. Now
where are those Higgs particles? :confused:
Hi,
From what I know, the Higgs field and the curvature of space are not alternative descriptions.
The Higgs field describes why particles (mass) need a force to be moved through space (= space is "something") and that an acceleration of a particle can be measured against space itself (not only against other particles, see also SRT).
Chronos said:
It is more accurate to think of gravity as an allergic reaction by space to the presence of matter [space curves around it].
A mass particle experiences both at the same time: the curvature of space was well as the Higgs field. The acceleration principles of the SRT (here: Higgs field) apply also under the GRT which comprehends gravitation.
Take care,
Carsten
  • · Replies 24 ·
  • · Replies 31 ·
