Capacitor with partially inserted Dielectric
The problem involves a parallel-plate capacitor initially filled with air, which is charged and then disconnected from a battery. The discussion centers around the effects of inserting a dielectric material and subsequently pulling it partway out, specifically focusing on the voltmeter readings before and after these changes.
  • Mixed
  • Participants explore the relationship between voltage readings with and without the dielectric, questioning how to calculate the dielectric constant and the voltmeter reading when the dielectric is partially removed.
Some participants have offered equations related to capacitance and charge, while others are attempting to clarify the setup and reasoning behind the calculations. There is a mix of interpretations regarding how to approach the problem, particularly in determining the effective capacitance and voltage.
Participants are grappling with the implications of charge conservation and the differing charge densities in regions with and without the dielectric. There is also confusion regarding the correct application of formulas for capacitors in parallel versus series.
joshanders_84
This is one of my homework problems that I am stumped with:
A parallel-plate capacitor with only air between the plates is charged by connecting it to a battery. The capacitor is then disconnected from the battery, without any of the charge leaving the plates.
A) A voltmeter reads V_1 when placed across the capacitor. When a dielectric is inserted between the plates, completely filling the space, the voltmeter reads V_2. What is the dielectric constant of this material?
I know the answer to this: it is V_1/V_2 (as the definition of K).
B) What will the voltmeter read if the dielectric is now pulled partway out so it fills only one-third of the space between the plates?
I don't understand how to answer this one. I have tried going into the definition of capacitance with and without a dielectric, and came up with V_1/(k/3), but that is not the right answer. I don't understand how to figure this out...any and all help is much appreciated. Thank you
Use the equation C = Q/V = (epsilon*S)/d
In the case when you only have free space what is V1?
For the case where you have 1/3 dieletric and 2/3 free space you can split the problem into two capacitors in parallel.
In that case, shouldn't it be (1/3)V_2 + (2/3)V_1? I have tried that but it is incorrect and I really just don't seem to get it.
Um, no. I believe the answer should only have a V1.
Remember that the total charge doesn't change, but the charge density in the region with the dielectric will be different from the region without. The charges must end up distributed so that the voltage is the same everywhere on the plates.
Ed: Solve for Ceq as dduardo suggested. Then find an expression for Q in terms of V1 and use the fact that Ceq = Q/Vf
PS: I wouldn't stake my life on it, but my answer has both V1 and V2 in it. :smile:
But in this case, Ceq is equal to what? I mean how can I solve for that?
In effect you have 2 capacitors in parallel, so use
[tex]\frac{1}{C_{eq}}=\frac{1}{C_1} + \frac{1}{C_2}[/tex]
You can express C1 as a function of ε0, d, A, and V1 and C2 as a function of ε0, d, A, and V2.
Put all of that together, along with the knowledge that Q is a constant that you can express as a function of ε0, d, A, and V1 or V2, will give you the answer.
gnome, the equation you gave is for capacitors in series. You just add the capacitor values in parallel: C1+C2+...Cn
Hmmm...resistance, capacitance... can't keep 'em straight after 1 year
Yes, you're absolutely right. Thanks.
So,
[tex]C_{eq}={C_1} + C_2[/tex]
gives me
[tex]V_f = \frac{3V_1V_2}{V_1 + 2V_2}[/tex]
Do you agree?
  • · Replies 17 ·
