How Does Gauss's Law Apply to Dielectrics with Embedded Point Charges?
The discussion revolves around applying Gauss's Law to a scenario involving a point charge embedded in a dielectric material. Participants are exploring the implications of the dielectric constant on the electric field and charge distribution within the material.
  • Participants are attempting to understand how to apply Gauss's Law in the context of dielectrics, with specific focus on the equations provided. There are questions regarding the interpretation of boundary conditions and the relationship between electric fields in free space and within a dielectric. Some participants express confusion about charge density and its implications.
The discussion is ongoing, with participants providing hints and guidance without reaching a consensus. Some have suggested focusing on the fundamental concepts of electric fields and charge distribution, while others are clarifying the equations involved.
Participants are grappling with the definitions and implications of Gauss's Law as it pertains to dielectrics, and there are indications of confusion regarding the mathematical representation of the problem. The original poster expresses a lack of understanding of Gauss's Law, which is central to the discussion.
joshanders_84
This problem is also giving me a lots and lots of trouble, and I don't even know where to begin.
A point charge q is imbedded in a solid material of dielectric constant K.
A) Use Gauss's law as stated in equation \oint{K \vec{E} \cdot \vec{A}} \;=\; \frac{Q_{free}}{\epsilon_{0}} to find the magnitude of the electric field due to the point charge q at a distance d from the charge.
B) Use your result from part (a) and Gauss's law in its original form as given in equation \oint{\vec{E} \cdot \vec{d A}}\; =\; \frac{Q_{encl}}{\epsilon_{0}} to determine the total charge (free and bound) within a sphere of radius d centered on the point charge q.
C) Find the total bound charge within the sphere described in part (b).
I obviously need A before doing B and C, but I don't even know how to get it. I didn't fully understand Gauss law in the first place, so now I am even more confused. Any help appreciated, thanks.
I think you'll have to do a better job with those equations so people can help you without spending all night trying to decode the question.
Here is a hint:
E and D are in the radial direction. That means that there will never be a tangential component. Now all you have to figure out is what the normal component is. This is just a simple boundary condition problem.
what do you mean a boundary condition problem? I am confused a bit, I'm afraid to say.
those two equations, which I thought would show up properly, are:
integral KEA = Q(free)/epsilon_0
and
integral EdA = Q(enclosed)/epsilon_0
Forget about the formulas and just think for a moment. In the case when you have a charge in free space what is the electric field at some point due to the charge? Once you can answer that question using Gauss's Law you'll be ready to move on to the second part which is: how is an electric field affected by a dielectric boundary.
The electric field from some point is given by a formula, right? Specifically Kq/(r^2)
yes, now what is the relationship between En inside the dielectric and En inside free space.
the dielectric has a charge built up on the sides of it? And this would effect E?
Ok, so what is the charge density?
I honestly am not sure of the charge density. I know this sounds dumb but I don't know...?
[tex]Q = \int \rho dV[/tex] where rho is the charge density
This may help:
http://www.shef.ac.uk/physics/teaching/phy205/lectures_8_and_9.htm
Specifically: Gauss’s Law in dielectrics, D-field
  • · Replies 26 ·
  • · Replies 30 ·
  • · Replies 78 ·
