How to Solve Exact Differential Equations with Discontinuous Functions?
The discussion focuses on solving the first-order linear differential equation dy/dx + y = f(x), where f(x) is defined as 2 for 0 ≤ x < 1 and 0 for x ≥ 1, with the initial condition y(0) = 0. The integrating factor used is e^x, leading to the equation e^x y(x) = ∫_0^x tf(t) dt. The integral evaluates to 2(e^x - 1) for 0 ≤ x < 1 and 2(e - 1) for x ≥ 1, clarifying the behavior of the solution across the discontinuity at x = 1.
  • Understanding of first-order linear differential equations
  • Knowledge of integrating factors in differential equations
  • Familiarity with piecewise functions
  • Basic integration techniques
  • Study the method of integrating factors in depth
  • Learn about piecewise continuous functions and their applications
  • Explore the concept of discontinuities in differential equations
  • Practice solving similar differential equations with varying functions
Students and professionals in mathematics, particularly those studying differential equations, as well as educators looking for examples of solving equations with discontinuous functions.
mehtamonica
i have to solve the following differential equation :
dy/ dx + y = f(x) where f (x) = 2, 0 <= x < 1 and 0 if x >=1
and y (0)=0.
please explain how to solve it as it involves a discontinuous function ?
I am stuck while computing after computing the integrating factor e^x. Please suggest how to proceed beyond this.
Yes, the integrating factor is [itex]e^x[/itex]. Multiplying both side of the equation by [itex]e^x[/itex] you have
[tex]e^x\frac{dy}{dx}+ e^xy= e^xf(x)[/tex]
[tex]\frac{d(e^xy)}{dx}= e^xf(x)[/tex]
Integrate both sides to get
[tex]e^x y(x)= \int_0^x tf(t)dt[/tex]
(I chose the lower limit of integration to be 0 because the integral of any function from 0 to 0 so that gives y(0)= 0.)
I suspect it is that integration that is bothering you. Take it "step by step".
For [itex]0\le x\le 1[/itex] f(x)= 2 so [itex]e^xf(x)= 2e^x[/itex] on that interval.
[itex]\int_0^x 2e^t dt= 2(e^x- e^0)= 2(e^x- 1)[/itex]
Of course, for that, if x= 1, [itex]2(e- 1)[/itex]
For x> 1, f(x)= 0 so [itex]e^x f(x)= 0[/itex]. [itex]\int_1^x 0 dx= 0[/itex] so [itex]\int_0^x e^xf(x)dx= 2(e- 1)[/itex].
That is, the integral is [itex]2(e^x-1)[/itex] for [itex]0\le x\le 1[/itex] and the constant [itex]2(e- 1)[/itex] for [itex]x\ge 1[/itex].
Thank a lot for this guidance, but i still have a doubt and hope that you may help me out this time as well. when f(x)=0 for x>=1 then how do we substitute x=1 in the solution obtained for 0<=x<1? please enlighten me on this
  • · Replies 52 ·
10K
