What is meant by saying that the Goldstone-bosons are eaten by gauge bosons?
The discussion focuses on the concept of Goldstone bosons being "eaten" by gauge bosons, particularly in the context of spontaneous symmetry breaking in field theories. Participants explore the implications of this phenomenon using examples from scalar fields and gauge fields, examining the degrees of freedom involved and the role of gauge invariance.
  • One participant asks for clarification on the meaning of Goldstone bosons being "eaten" by gauge bosons, indicating a lack of understanding of the concept.
  • Another participant explains the mechanism using a complex scalar field coupled to an abelian gauge field, detailing how spontaneous symmetry breaking leads to a massless scalar field (Goldstone boson) and a massive gauge field.
  • A further explanation highlights that in the presence of a gauge field, the Goldstone boson can be eliminated through gauge invariance, redistributing degrees of freedom between the massive scalar and the massive gauge field.
  • A participant references the Mexican hat potential to illustrate the concept, noting that without a gauge field, the angular degree of freedom corresponds to a physical Goldstone mode, but with a gauge field, it becomes a gauge transformation and is thus "eaten."
  • One participant expresses understanding of the explanations provided, indicating clarity in the discussion.
Participants generally agree on the mechanism of Goldstone bosons being "eaten" by gauge bosons, but the initial question indicates some uncertainty about the concept itself. The explanations provided seem to clarify the topic without resolving all potential nuances or interpretations.
The discussion relies on specific assumptions about gauge invariance and the nature of scalar fields, which may not be universally applicable. The explanations provided depend on the context of the theories discussed and the mathematical formulations involved.
FredMadison
What is meant by saying that the Goldstone-bosons are "eaten" by gauge bosons?
I've seen this statement all over, but can't find a good explanation of what this actually means. Anyone care to shed some light?
To see how this works, let's consider a specific example of a complex scalar field, [itex]\phi[/itex], coupled to an abelian gauge field. The complex scalar has 2 real degrees of freedom, while the massless gauge field also has 2 real degrees of freedom after imposing gauge invariance. A massive abelian vector field has 3 real degrees of freedom, which will become important below.
If the scalar potential only depends on the modulus of the scalar field, [itex]V(\phi) = V(|\phi|)[/itex], then the Lagrangian has a continuous symmetry amounting to rescaling [itex]\phi[/itex] by a phase, [itex]\phi \rightarrow e^{i\theta} \phi[/itex]. Now suppose that this potential has a minimum at [itex]|\phi|=\upsilon[/itex]. We say that the symmetry is spontaneously broken because the vacuum state [itex]\langle \phi \rangle = \upsilon[/itex] is no longer invariant under the phase symmetry of the Lagrangian.
If we parameterize
[itex]\phi = (\rho + \upsilon) e^{i\alpha},[/itex]
we find that the Lagrangian only depends on the derivatives [itex]\partial_\mu \alpha[/itex] of the phase field. So [itex]\alpha[/itex] is a massless real scalar, while [itex]\rho[/itex] is a massive real scalar field. Furthermore, there is an continuous invariance where [itex]\alpha \rightarrow \alpha + c[/itex], which is nothing more than the phase symmetry of the theory. If there were no gauge field coupled to [itex]\phi[/itex], we would identify [itex]\alpha[/itex] with the Goldstone boson corresponding to the spontaneous breaking of the phase symmetry of the complex field.
However, in the presence of the gauge field, the total theory has a local gauge invariance [itex]\phi \rightarrow e^{i\theta(x)} \phi[/itex], [itex]A_\mu \rightarrow A_\mu - i \partial_\mu \theta(x)[/itex]. We are free to use this gauge invariance to set [itex]\theta = -\alpha[/itex]. This eliminates the field [itex]\alpha[/itex] from the Lagranian entirely, leaving terms for the massive [itex]\rho[/itex] and massive vector field [itex]A_\mu[/itex] and their interactions. The 2+2 real degrees of freedom we started with are now distributed as 1 real d.o.f. for [itex]\rho[/itex] and the 3 real d.o.f. for the massive gauge field.
The use of the gauge symmetry to eliminate the phase [itex]\alpha[/itex] in favor of the extra degree of freedom for the massive gauge field is what's referred to as "eating" the Goldstone boson.
Look at the Mexican hat potential as described in fzero's post: http://www.nature.com/nphys/journal/v7/n1/images/nphys1874-f1.jpg
w/o a gauge field you would have a physical 'angular degree of freedom' rolling in the well with mass zero. But with a gauge field the 'angular degree of freedom' is no longer physical b/c this 'rolling' is just a gauge transformation and can be rotated away. So this angular zero-mass Goldstone mode 'is eaten' by the gauge boson.
Ok, I think I see how this works. Very clear answers, thank you!
  • · Replies 19 ·
