Register to reply
Astronomy - Measure distance to other galaxies
Share this thread:
tosv
#1
Sep16-11, 02:39 AM
P: 13
I have understand that the Parallax method can be used to measure the distance to stars, but what happens when the parallax angle gets to small to be measures accurate?
What kind of methods are used to measure distance to star that are like 5000 light years away, or to Superclusters that are maybe 1 000 000 000 light years away?
Phys.Org News Partner Astronomy news on Phys.org
Spectacular supernova's mysteries revealed
Supernova seen in two lights
A chemical signature of first-generation very-massive stars
Drakkith
#2
Sep16-11, 05:11 AM
Mentor
Drakkith's Avatar
P: 11,844
For close by objects, such as the Andromeda Galaxy, we can see a type of star called a Cepheid variable. These have variations in brightness that occur in cycles. These cycles vary themselves, however it was found that the brightness of the star was directly related to the time between cycles. Meaning that the dimmer stars are on a different cycle than the brighter stars. By measuring how bright these stars are and their cycles, we know about how far away they are.
Supernova are another way we can judge distance. A type 1a supernova is the result of a White Dwarf star accumulating matter on it's surface until the extra mass results in the collapse of the star in a supernova. Type 1a supernovas are all very similar, as they all result from an almost identical set of circumstances, so again we can judge distance based on the light emitted from the supernova.
twistedspark
#3
Sep16-11, 08:11 AM
P: 23
Quote Quote by Drakkith View Post
...and using this presumedly accurate method to gauge extremely distant galaxies comes back with measurements showing that the expansion of the universe is accelerating. Uh oh, better come up with something to sell this to people with. Let's call it...[cue ominous music] "Dark Energy!"
Lol
zhermes
#4
Sep20-11, 10:43 AM
P: 1,261
Quote Quote by tosv View Post
Drakkith gave an excellent answer for moderate distances.
At larger distances (i.e. larger than millions of light-years) cosmological effects (e.g. Hubble's Law) are essentially the only method of determining distance. Because the universe is expanding everywhere, the farther away something is---the faster its moving away (this applies to the average motion at very large scales). Thus if you measure how fast something is moving away (via the Doppler Effect) you can estimate how far away it is.
zhermes
#5
Sep20-11, 10:45 AM
P: 1,261
Quote Quote by twistedspark View Post
Lol
If you're bemused by such lofty concepts, feel free to ask questions to clarify your understanding.
DaveC426913
#6
Sep20-11, 10:57 AM
DaveC426913's Avatar
P: 15,319
What laypeople often fail to realize is that no one method is used to calculate distances. Many methods, built on many decades of research cause us to arrive at these numbers. One method (say, parallax) will provide an upper and lower bound to distances and/or a margin for error. Another independent method (say, Cepheids) provide another set of bounds. The two methods combine, resulting in an intersection of limits and of margins of error, the outcome being much smaller than any one method alone.
Do this with multiple methods, with a large data set, and do it with objects very close, where the margins of error are small, and you can generate some pretty reliable techniques.
Do not judge unless you know what you're talking about.
twofish-quant
#7
Sep26-11, 02:54 AM
P: 6,863
Here is a good article with a good graph on how everything fits together....
http://en.wikipedia.org/wiki/Cosmic_distance_ladder
twofish-quant
#8
Sep26-11, 03:00 AM
P: 6,863
Lol
Here are the two major papers on the topic
http://adsabs.harvard.edu/abs/1998AJ....116.1009R
http://adsabs.harvard.edu/abs/2004ApJ...607..665R
They are pretty good examples of scientific reasoning. They do a pretty good job of going through all of the possible observational errors and then explaining why none of them will work. At this point dark energy is weirder, but any of the other explanations are even weirder.
Also people are looking for other ways of measuring extragalactic distances. The wikipedia article lists seven.
twofish-quant
#9
Sep26-11, 03:06 AM
P: 6,863
Quote Quote by DaveC426913 View Post
The other thing is that people use different methods with different physics to calculate the same number. If you end up with roughly the same number, you get a nice warm feeling that you may have something close to the real number.
It's also the situation that people are always trying to think of new things.
Drakkith
#10
Sep27-11, 10:29 PM
Mentor
Drakkith's Avatar
P: 11,844
Quote Quote by Doreen View Post
Continue learning. The astronomy is still have more thing need we think and "dig".
Doreen do you speak english as a first language? It is very difficult to understand you.
Register to reply
Related Discussions
Astronomy - Distance with different scale factors Introductory Physics Homework 3
Measure distance of devices via radio? Electrical Engineering 3
Dark Energy, Distance to Galaxies and Distance in time. Cosmology 3
Measure of Distance to Stars Special & General Relativity 2
How to measure the Distance from Earth to Sun? Astronomy & Astrophysics 11
