Solving for Phi in Harmonic Motion Equation
The discussion focuses on solving for the phase constant, phi, in the harmonic motion equation for a spring system with a spring constant of 190 N/m and an amplitude of 8.0 cm. The mass of 0.380 kg passes through the equilibrium point at t = 0.100 s. The equation of motion is given by x = A*cos(omega*t + phi), where A is 8.0 cm and omega is calculated to be 22.36 rad/s. The correct approach to find phi involves recognizing that the mass is moving upwards at t = 0.100 s, which leads to a unique solution for phi.
  • Understanding of harmonic motion equations
  • Knowledge of spring constants and mass-spring systems
  • Familiarity with trigonometric functions and their inverses
  • Ability to perform basic calculus and physics calculations
  • Study the derivation of the harmonic motion equation x = A*cos(omega*t + phi)
  • Learn about the significance of phase constants in oscillatory motion
  • Explore the implications of initial conditions on harmonic motion
  • Investigate the relationship between angular frequency and spring constant in mass-spring systems
Physics students, mechanical engineers, and anyone studying oscillatory systems will benefit from this discussion, particularly those focusing on harmonic motion and spring dynamics.
lmf22
A spring with spring constant 190 N/m vibrates with an amplitude of 8.0 cm when 0.380 kg hangs from it.
What is the equation describing this motion as a function of time?
Assume the mass passes through the equilibrium point, toward positive x (upward), at t = 0.100 s.
x=A*cos(omega*t + phi)
I figured out that A is 8.0 cm, and omega is 22.36
but I can't figure out phi.
Here's what I did:
x=0 (because it's at equalibrium at .100 s)
Plug in numbers and get
0=A*cos(22.36*.100 + phi)
0/A = cos(22.36*.100 + phi)
arcosine(0) = 22.36*.100 + phi
phi = arcosine(0) - (22.36*.100)
What am I doing wrong?
There are many solutios for [itex]\phi[/tex]. Perhaps you're looking for a particular one? Perhaps you should use the fact that the mass is moving upwards at time [itex]t=0.100[/tex]?[/itex][/itex]
Ah! I got it! Thank you.
