Solving a Limit to Determine the Convergence of a Series
The discussion revolves around determining the convergence of the series \(\sum_{n=1}^{\infty}(-3)^{n-1}4^{-n}\). Participants explore the implications of limits and the behavior of the series as \(n\) approaches infinity.
  • Participants discuss rewriting the series in terms of limits and fractions, questioning the oscillation of the numerator and the behavior of the denominator as \(n\) increases. There is also a suggestion to factor out terms to align exponents and consider the series as a geometric series.
Some participants express confusion regarding the evaluation of the limit and its implications for convergence. There are indications of productive dialogue, with suggestions to analyze the series further by examining its terms and considering the nature of geometric series.
Participants note the necessity of the limit evaluating to zero for convergence, while also recognizing that this alone does not guarantee convergence. There is an emphasis on understanding the series structure and behavior.
BraedenP
I am asked to determine whether a series converges, and if so, to provide its sum.
The problem is:
[tex]\sum_{n=1}^{\infty}(-3)^{n-1}4^{-n}[/tex]
- I know that if the limit of the sequence as n->inf is finite, then the series converges at that limit.
- I also know that the sum of the given series is equal to said limit (if it exists).
1. I rewrote the series as a limit and turned it into a fraction: [tex]\lim_{n\rightarrow\infty}\frac{(-3)^{n-1}}{4^n}[/tex]
2. Then as [itex]n\rightarrow\infty[/itex] the denominator approaches infinity, and the numerator begins to oscillate (for even n values, it's a large positive number, and for odd n values it's a large negative number).
3. Thus, I concluded that the limit does not exist, and thus the series does not converge.
However, this limit actually evaluates to 0, meaning that the series converges and sums up to 0. How is this? I'm quite confused...
The problem is:
Pull a factor of 1/4 out to get the exponents aligned, so that what you're summing is [tex]\left(\frac{-3}{4}\right)^{n-1}[/tex]
Oh, okay. That makes sense. Thanks!
BraedenP said:
Okay.. That makes sense, but in this case the limit evaluates to infinity, doesn't it? It should evaluate to 0.
[itex]\displaystyle \lim_{n\to\infty}\left(\frac{-3}{4}\right)^{n-1}=0[/itex]
This is necessary for the series (the sum) to converge, but it's not enough to guarantee it.
That will take a bit more work.
As a start, write out the first several terms ot the series, then look at the sum of any two consecutive terms of the series.
Alternatively, this is a geometric series, which is probably one of the first series presented when you started learning about series.
Yeah, thanks guys. I was reading that all wrong. Makes perfect sense now :)
