New Reply
Heat Transfer Through a Plane Wall
Share Thread Thread Tools
Sep16-11, 05:17 PM   #1
Consider a large plane wall of thickness L = 0.4m, thermal conductivity k = 1.8W/(m*K), and surface area A = 30m2. The left side of the wall is maintained at a constant temperature of T1 = 90 C while the right side looses heat by convection to the surrounding air at Ts = 25 C with a heat transfer coefficient of h = 24 W(m2*K). Assuming constant thermal conductivity and no heat generation in the wall evaluate the rate of heat transfer through the wall.
Answer: 7079 W
My answer doesn't match the book's answer.
2. Relevant equations
[tex]\dot{Q}_{wall} = -kA\frac{dT(0)}{dx}[/tex]
[tex]\frac{d^2T}{dx^2} = 0[/tex]
[tex]T(0) = 90[/tex]
[tex]-k\frac{dT(L)}{dx} = h[T(L) - Ts][/tex]
3. The attempt at a solution
Solving the differential equation and applying B.C.:
[tex]T(x) = xC_1 + C_2[/tex]
[tex]T(0) = C_2 = 90[/tex]
[tex]-kC_1 = hLC_1+hC_2-25h][/tex]
[tex]C_1 = -\frac{h(C_2-25)}{k+hL}[/tex]
Plugging numbers in:
[tex]C_2 = 90[/tex]
[tex]C_1 = -136.8[/tex]
[tex]T(x) = 90-136.8x[/tex]
[tex]\dot{Q}_{wall} = -1.8*30*(-136.8) = 7,387 W[/tex]
Did I make a mistake or is the book's answer wrong?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Sep17-11, 06:40 AM   #2
Recognitions:
Gold Membership Gold Member
I used a somewhat different approach (underlying equations are of course the same) and got the same answer you did.
I computed the thermal resitance of the wall as L/kA = 7.41e-3 K/W and the equivalent thermal resistance of the convection effect as 1/hA = 1.39e-3 K/W, giving total thermal resistance of 8.80e-3 K/W so dQ/dt = (90 - 25)/8.80e-3 = 7387W.
Just curious - what is your textbook?
Sep17-11, 01:58 PM   #3
Awesome thanks, I didn't want to waste any more time redoing this problem looking for a mistake, and my class is just starting the thermal resistance chapter so if I see more problems that have wrong answers I'll do them that way to check.
We're using Heat and Mass Transfer Fundamentals & Applications 4th Ed by Cengel and Ghajar.
Oct18-11, 02:58 PM   #4
arent we suppose to take temp. as kelvin here?
Oct18-11, 03:33 PM   #5
Recognitions:
Quote by spree View Post
It's OK to interchange K and C as long as you're dealing with temperature differences.
Oct18-11, 03:45 PM   #6
oh ure right. new to the subject, just trying to learn sorry :) btw I personally know professor cengel and i will inform him about this. I will let you know about it. if you suspect any other mistake in the book feel free to ask please.
New Reply
Thread Tools
Similar Threads for: Heat Transfer Through a Plane Wall
Thread Forum Replies
The dynamic heat transfer in tube wall Nuclear Engineering 5
Plane Wall Heat transfer Classical Physics 5
Radiation heat transfer between air or wall General Physics 6
Question on heat transfer of a plane wall Introductory Physics Homework 1
Heat Transfer from metal wall Engineering, Comp Sci, & Technology Homework 0
