To write x as a function of time doubt.
The discussion revolves around the conceptual understanding of kinematic equations in physics, specifically the relationship between position, velocity, and acceleration as functions of time. The original poster questions the equivalence of two kinematic equations when substituting known variables.
  • The original poster attempts to derive one kinematic equation from another and questions the validity of their results based on specific values for initial and final velocities, time, and acceleration. Some participants question the physical plausibility of the chosen values and explore the conditions under which the equations are equivalent.
The discussion is ongoing, with participants exploring the implications of the chosen values and their physical significance. Some guidance has been offered regarding the physical constraints of the variables involved, but there is no explicit consensus on the interpretation of the equations.
Participants note that the values selected by the original poster may not be appropriate, as they lead to contradictions in the context of the equations. There is an emphasis on understanding the physical meaning behind the variables and their relationships.
naaa00
Hello!
It is more a conceptual problem. If all the variables are known, and I am asked to write x as a function of time, why the equations below are not equivalent when equation (b) is derived from (a) after substituting "v_f = v_i + at" ?
(a) x_f = x_i + 1/2(v_f + v_ i)(t)
(b) x_f = x_i + v_i(t) + 1/2(a)(t^2)
If I suppose: x_i = 0, v_f = 50, v_i = 0, t = 5, and a= 3.33. Am I supposed to get same answers? It seems not, and I don't understand why.
I could say that x = 0 + 1/2(a)(t^2) = 1/2(3.33)(t^2) or x_f = 1.67(t^2). [using (b)]
But for (a) x_f = 0 + 1/2(50)(t) or x_f = 25(t)
These numbers don't make sense. (You can't just pick arbitrary values and expect it to work.)
Ok. But may I ask two more questions?
(a) Why these numbers do not make sense? physicaly impossible? What sort of numbers would make sense?
(b) And if looked from a mathematical point of view, why both equations must have particular values in order to be equivalent? Or are they not equivalent?
Yes, those numbers are physically impossible. For example: If vi = 0, vf = 50, t = 5, then a is determined by the physics to be 50/5 = 10 m/s2.
(b) And if looked from a mathematical view, why both equations must have particular values in order to be equivalent? Or are they not equivalent?
They are equivalent.
Well, now I see clearly the mistake. I am only going to say that this is depressing. Perhaps I need some rest.
Thank you!
  • · Replies 16 ·
  • · Replies 19 ·
