Bending of a varrying cross section
The discussion focuses on calculating the moment of inertia for a beam with a varying cross-section to create a stress-strain graph. The user is struggling to identify the correct axis for calculations, specifically the z-axis, while the height remains constant. A suggestion was made to calculate the moment of inertia at various locations along the beam and plot it against the distance from the fixed end. This approach will provide a clearer understanding of how the moment of inertia changes along the beam.
  • Understanding of beam mechanics and structural analysis
  • Familiarity with moment of inertia calculations
  • Knowledge of stress-strain relationships in materials
  • Ability to interpret engineering diagrams and axes
  • Calculate moment of inertia for varying cross-sections using the parallel axis theorem
  • Learn how to create stress-strain graphs from experimental data
  • Explore beam bending theory and its applications in structural engineering
  • Investigate software tools for simulating beam behavior under load
Engineering students, structural analysts, and professionals involved in material testing and beam design will benefit from this discussion.
rayray0071
Recently, I had lab. In the lab we took different objects and measured their strain. One object had a varying cross section. The data for strain was recorded. Right now, I'm trying to make a stress strain graph, but the problem is my equation for stress. I don't know how i can take my moment of intertia about the z-axis. I looked all over the web. In addition, I tried contacting my TA but no success for the pass 3 days. If you can help, I would appretiate it.
Edit: I have the equations for the slopes. The problem lies with my moment of inertia.
The problem as shown leaves one asking a few questions. I don't know which is the z-axis.
According to the problem statement, the depth of the beam is constant; apparently only the width varies. Why don't you calculate the moment of inertia at several different locations and draw a curve of inertia versus distance from the fixed end?
rayray0071:
Are you certain that you need to solve for more than two dimensions?
According to your problem statement, your height (i.e., your x-axis) is of constant dimensions.
As your diagram is, according to your problem statement, viewed from above, it's your x-axis that's sticking out from the paper. The only varying dimension is the z-axis (which is the up-and-down axis on your diagram). The y-axis is, as usual, the left-right axis on your diagram.
I hope this helps.
  • · Replies 30 ·
10K
