| New Reply |
Use the cross product to find the sin of an angle then prove it |
Share Thread | Thread Tools |
| Sep17-11, 05:48 PM | #1 |
Leta theta be the angle between the vectors u=2i +3j -6k and v=2i + 3j+6k A) use the dot product to find cos theta b) use the cross product to find sin theta c) confirm that sin^2(theta) + cos^2(theta)=1 3. The attempt at a solution I got a to be 117 degrees, but however b and c are stumping me, whenever I try to do b I get an the cross product and then try to solve for theta but i get an error using my calculator, I rechecked my calculations twice and everything make sense am I doing something wrong or is it really not possible. |
| Sep17-11, 06:02 PM | #2 |
Recognitions:
It would be more helpful to someone assisting you if you explained what you did for part (b), in order to understand why you are getting an error...
(And I get an angle of 118º for theta.) |
| Sep17-11, 07:01 PM | #3 |
well all i did was the cross product of u and v which came out to 36i -24j+0k and i took the norm of that which came out to 12*sqrt(13) and I divided that by the norm of u * the norm of v which is 49. so I had 12*sqrt(13)/49 and i took the inverse sin of that. which would obviously give me an error. But I dont see what I did wrong all my calculations are correct.
| Sep17-11, 07:21 PM | #4 |
Recognitions:
Use the cross product to find the sin of an angle then prove itCheck how you have input [itex] \frac{12\sqrt{13}}{49} [/itex] ; this is a positive number smaller than 1 . Is your "error" that you don't get the same angle as you did for the arccosine? Don't forget that the range of arccosine is 0º to 180º , but the range of arcsine is -90º to 90º ; the arcsine result for theta (out of a calculator) is the supplement of the correct value. (The angle theta is in the second quadrant.) Part (c) sidesteps this anyway, since you are simply asked to sum the squares of your values from parts (a) and (b)... [EDIT: You must have gotten cos(theta) = -23/49 to get the angle of 118º . The sum of the squares does give you 1 .] |
| Sep17-11, 10:48 PM | #5 |
ah awesome man, I got it thanks for your help!!!
| New Reply |
| Thread Tools | |
Similar Threads for: Use the cross product to find the sin of an angle then prove it
| Angle between 2 vectors using 1) Dot product and 2) cross product gives diff. answer? | Calculus & Beyond Homework | 8 | ||
| Using cross product to find angle between two vectors | Calculus & Beyond Homework | 5 | ||
| Find theta from the cross product and dot product of two vectors | Calculus & Beyond Homework | 11 | ||
| Find angle to eliminate cross product term | Calculus & Beyond Homework | 1 | ||
| Prove whether Cross-Product is associative | Precalculus Mathematics Homework | 5 | ||
