New Reply
distance unknown, have acceleration time and another distance
Share Thread Thread Tools
Sep17-11, 09:56 PM   #1
A rock is thrown up past a window. The rock requires 0.20 s to completely pass by the 1.4 m window calculate the height above the window the rock would travel.
2. Relevant equations
D=vf(t) -1/2at^2
3. The attempt at a solution
I have tried using the acceleration as 9.81 m/s and 7 m/s and the vf as i got that from 1.4/0.20. It does not give me the right answer though. any help would be great!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Intel's Haswell to extend battery life, set for Taipei launch
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
Sep17-11, 10:35 PM   #2
Recognitions:
Gold Membership Gold Member
What you are given is time for completing 1.4m is 0.2s, can you find the initial velocity of stone using this data?
Sep17-11, 11:10 PM   #3
So i found that the initial velocity is 6.019 m/s now how does that lead me to how far above the window the rock will travel?
Sep17-11, 11:14 PM   #4
Recognitions:
I don't get my answer to be 6.019m/s.
Show me the steps you followed.
Sep17-11, 11:29 PM   #5
Quote by Pranav-Arora View Post
1.4m=vi(.20)+1/2(9.81)(0.20)^2
1.4=vi(0.20)+.1962
1.2038=vi(0.20)
vi=6.019m/s
Sep17-11, 11:33 PM   #6
Recognitions:
Quote by vicsic View Post
1.4=vi(0.20)+.1962
1.2038=vi(0.20)
vi=6.019m/s
Ah...there you go wrong.
The direction of acceleration which is g in our case is opposite to the initial velocity.
Initial velocity is in upward direction and acceleration is in downward direction. So one has to be negative. That means you didn't take care of signs. If you choose upward as positive then downward direction has to be negative.
Try again & post the steps here.
Sep18-11, 08:56 AM   #7
Got the answer!
1.4m=vi(0.20)+1/2(-9.81)(0.20)^2
1.4m=vi(0.20)-0.1962
1.5962=vi0.20
vi=7.981 m/s
then plugging it back in
d=vi(t)+1/2at^2
d=7.981(0.20)+1/2(9.81)(0.20)^2
d=1.7924
d=1.8m
thanks for the help :)
Sep18-11, 09:54 AM   #8
Recognitions:
Got the answer!
1.5962=vi0.20
vi=7.981 m/s
d=vi(t)+1/2at^2
d=1.7924
d=1.8m
You're still incorrect. :)
When you substituted the value of vi back into the same equation, you did a sign mistake again.
Moreover, you aren't asked the initial velocity in the question.
You are asked how high it would go above the window.
For that you need to find the maximum height the stone can achieve.
(Hint: Velocity at maximum height is 0m/s).
Try again and post the steps here. :)
New Reply
Tags
acceleration, distance, kinematics, velocity
Thread Tools
Similar Threads for: distance unknown, have acceleration time and another distance
Thread Forum Replies
Acceleration, distance, time. help. Calculus & Beyond Homework 3
Acceleration from Time & Distance. Introductory Physics Homework 4
Acceleration/distance/time problem.. Introductory Physics Homework 3
Distance in time at acceleration Introductory Physics Homework 7
Distance, acceleration, and time.. Introductory Physics Homework 3
