Is a System Causal if the Output Anticipates the Input?
  • Thread starter Thread starter johnstamos
    Systems
This discussion centers on the concept of causality in systems, specifically whether a system is causal if its output anticipates its input. A causal system, defined by the relationship y[n] = F[x(n)], does not depend on future input values, meaning y[N] relies solely on x[n] for n≤N. The example provided, y[n] = sin[n], is deemed causal as it does not require future input values. In contrast, a non-causal system example, y[n] = x[n] + x[n+1], necessitates knowledge of future inputs, thus confirming its non-causality.
  • Understanding of discrete-time signals and systems
  • Familiarity with the concept of causality in signal processing
  • Knowledge of mathematical functions and their properties
  • Basic grasp of time-domain analysis in systems
  • Study the properties of linear time-invariant (LTI) systems
  • Learn about the implications of non-causal systems in signal processing
  • Explore the concept of system stability and its relation to causality
  • Investigate the use of the Z-transform for analyzing system behavior
Students and professionals in electrical engineering, signal processing, and control systems who seek to deepen their understanding of system causality and its implications in real-world applications.
johnstamos
Hey guys, having a little trouble understanding whether or not a system is causal or not. I d'nt think this classifies as homework; at least I hope not.
Basically I'm confused as to how you would go about determining whether or not a system is causal.
For example, say any function x[n] = u[n];
So basically the signal is only active for n>=0;
y[n] = sin[n];
So you have an output for n<=0 when there is no signal propagating into the system. Thus I would assume that this system is non-causal, because the output is somehow anticipatory.
However, what if the output y[n] actually does depend on inputs of 0. So y[n] for n<=0 actually does result from x[n] = 0, wouldn't that make it causal then?
Not sure if this makes any sense whatsoever, hopefully someone can share some insight on this topic.
Hey,
I don't really understand your example. LKike you said a causal system means that the system is NOT anticipatory. This means that for a system y[n] = F[x(n)], y[N] does not depend on any values of x for values of n>N.
in your example y[n] = sin[n], the output y[N] at a given time N does NOT depend on any information after "time" N - so the system is causal.
One easy way to check is to think: can you determine the output y[N]with only knowing x[n] for n<=N. If you can, your system is causal.
It may help to see an example of a non-causal function:
As you can see here, you MUST know the value of x at N+1 in order to know the value of the output y[N].
yeah not the best english student!
basically if the system has input u[n] and output cos[n], then is that system causal?
Because the output has values for n<=0 whereas the input only has values for n>=0.
Therefore the output is anticipating the input? That's bascially my question.
  • · Replies 46 ·
