Trouble with convolution and system response to inputs
The discussion centers on solving a convolution problem involving an input signal x(t) and an impulse response h(t). The user initially approached the problem using a graphical method, reversing and shifting the input function to find overlapping intervals. After analyzing the intervals, the user concluded that for -1 < t < 0, the convolution result is represented by the equation c(t) = t + 1, indicating a rightward shift. Ultimately, the user resolved the confusion regarding the convolution output and confirmed the correct interpretation of the results.
  • Understanding of convolution integrals in signal processing
  • Familiarity with impulse response functions
  • Graphical analysis of functions and their transformations
  • Basic knowledge of time-shifting and time-reversing signals
  • Study the properties of convolution in linear time-invariant (LTI) systems
  • Learn about graphical methods for convolution in signal processing
  • Explore the implications of time-shifting and time-reversing on signal behavior
  • Investigate the use of MATLAB or Python for numerical convolution analysis
Students and professionals in electrical engineering, particularly those focusing on signal processing, as well as anyone looking to deepen their understanding of convolution and system responses to inputs.
Lolsauce
x(t) is input, h(t) is the impulse response, y(t) is output
Find the system response to the input x(t)
x(t): [PLAIN]http://img10.imageshack.us/img10/5157/55570988.jpg
h(t): [PLAIN]http://img593.imageshack.us/img593/1079/52492104.jpg
Now I know the convolution integral is (f*g)(t) = [URL]http://upload.wikimedia.org/math/d/1/2/d122f80c065a111d4617fb3afdae0e53.png[/URL]
But for this problem I took a more graphical approach
I changed the variable to T (Tau) and chose a function to be time reversed
So I took the input and shifted then reversed the graph giving me this:
[PLAIN]http://img13.imageshack.us/img13/8581/xtshiftandreverse.jpg
Afterwards I found t in which the graphs starts overlapping and not overlapping. I found at for t < -1, convolution c(t) = 0. So for my first intervals I looked at -1 < t < 0, which overlapping begins.
[PLAIN]http://img703.imageshack.us/img703/5655/widthj.jpg
This gives me a width of (t-2) - (-3) = t + 1 which should be the equation from -1<t<0.
I repeat the same process from 0 < t < 5, and this give me an obviously overlap and convolution of c(t) = 1.
Then for the overlap starts to leave, I get and equation of:
(t-3) - 3 = t - 6, this is from the endpoint of x(t-T) leaving h(t).
So at the end I get this graph, it seems kind of whack. Especially the first interval of -1 < t < 0. Can anyone give me some tips or see a mistake I've done.
[PLAIN]http://img69.imageshack.us/img69/7213/convolution.jpg
Nevermind, I just solved it, lolsauce. I turns from -1 < t < 0 the equation is t + 1, means it is shift to the right by one, NOT shifted up like I had thought.
