ODE - having trouble using method of undetermined coefficients
The discussion revolves around finding particular solutions to ordinary differential equations (ODEs) using the method of undetermined coefficients. The specific problems involve second-order linear ODEs with trigonometric forcing terms.
  • Participants explore potential forms for particular solutions based on the forcing terms. The original poster considers using terms involving trigonometric functions multiplied by powers of t due to the nature of the roots of the characteristic polynomial. Questions arise regarding the correctness of these assumptions and the multiplicity of roots.
The discussion includes attempts to clarify the characteristic equation and the implications of the absence of certain terms in the ODEs. Some participants offer hints and suggestions for refining the guesses for particular solutions, while others question the original poster's reasoning regarding the multiplicity of roots.
There is mention of specific instructions regarding the forcing term being a solution of the associated homogeneous solution, which may influence the approach to finding particular solutions. Participants are also considering the implications of the structure of the ODEs on their solution strategies.
amanda_ou812
Find a particular solution.
1. y'' +4y = 4 cos (2t) (for this problem, the instructions tell me that the forcing term is a solution of the associated homogeneous solution)
2. y'' + 16 y = 3 sin (4t)
1. I guess that Acos (2t) + Bsin (2t) was a solution but it did not work out. I am thinking that since the roots to the characteristic polynomial are 2i with a multiplicity of two this means that a basis for the homogeneous solution space is { cos (2t) + sin (2t) , t cos (2t) + t sin (2t)}. So I am thinking a better guess should be A t^2 cos (2t) + B t^2 sin (2t). Is this correct?
2. For this one I guessed Acos (4t) + Bsin (4t) was a solution but it did not work out (provided that I did my computation correctly). Any suggestions?
Thanks!
1) The characteristic equation is
[tex]r^2 + 4 = 0[/tex]
2i is not a multiplicity of 2...
since your ODE does not have y' term, what would be a better guess?
hint:
y=Acos(4t)
y''=-Acost(4t)
If I choose y =A cos (2t) Then wouldn't y'' = -4 A cos (2t) and then y'' + 4 y = 0
I figured it out
