Electron Collisions: How do Electrons Knock Loose Atoms?
  • Context: Undergrad
  • Thread starter Thread starter NSX
    Electrons X-rays
Electrons can knock loose other electrons from atoms, specifically tungsten, through inelastic collisions, as confirmed by the discussion. This process occurs via electromagnetic interactions, where the colliding electron transfers momentum and energy to the target atom's electrons, causing them to change orbitals. This phenomenon is similar to the photoelectric effect, but involves virtual photons. For further understanding, reference materials by Knoll or Leo on particle interactions are recommended.
  • Understanding of inelastic collisions in physics
  • Familiarity with electromagnetic force principles
  • Knowledge of atomic structure and electron orbitals
  • Basic concepts of particle interactions in matter
  • Research the principle of Secondary Electron Emission
  • Study the photoelectric effect in detail
  • Explore the workings of photomultipliers and scanning electron microscopes
  • Read about particle interactions in matter from Knoll or Leo
Physics students, researchers in particle physics, and professionals working with electron microscopy or radiation physics will benefit from this discussion.
NSX
@ howstuffworks.com, it says:
When a speeding electron collides with a tungsten atom, it knocks loose an electron in one of the atom's lower orbitals.
I thought that only photons could knock and electron loose.
How do electrons do the same?
[edit]
Actually, I was viewing http://www.cvm.okstate.edu/~groups/students/web/2001/diagimag/Physics_of_Radiology.ppt , and on slide 22-23, it shows the knocking loose of an electron with another electron as similar to a inelastic collision.
Is this indeed the case?
I hope this will help you
Hi
Your electron is interacting with electrons of your atom of tungstem through the electromagnetic force.
He is changing is momentum and losing kinematic energy during this interaction. This energy loss goes to electrons of the tungsten and makes them change of orbitals.
So, indeed, it is an inelastic collision, as in the photoelectric effect (exept that in our case, the photon interacting with the elctron is virtual...)
If you're looking for further informations, you can read the books of Knoll or Leo (interactions of particles and matter)
Bye
You may also want to look up the principle of Secondary Electron Emission. Photomultipliers, scanning electron microscopes, and many other devices make use of the emission of electrons by other electrons. So no, photons are not the only "agent" that can knock out electrons from solids or atoms.
Zz.
  • · Replies 17 ·
