How Does KMnO4 Oxidize Toluene to Benzoic Acid?
  • Thread starter Thread starter cuti_pie75
    Oxidation
The oxidation of toluene to benzoic acid using potassium permanganate (KMnO4) involves a mechanism where a hydrogen atom is abstracted, forming a benzyl radical. This radical subsequently reacts with water, typically the solvent in these reactions, to yield benzyl alcohol. The final step of oxidizing benzyl alcohol to benzoic acid is straightforward and does not involve radical species. The reaction pathway indicates the formation of either radicalic or cationic intermediates, with the benzyl cation or radical being crucial in the initial steps.
  • Understanding of oxidation-reduction reactions
  • Familiarity with radical and cation formation in organic chemistry
  • Knowledge of solvent effects in chemical reactions, particularly water
  • Basic grasp of organic reaction mechanisms
  • Study the mechanism of KMnO4 oxidation reactions in organic chemistry
  • Research the formation and stability of benzyl radicals and cations
  • Explore the role of solvents in oxidation reactions, focusing on water
  • Investigate related reactions involving CrO3 and their mechanisms
Chemistry students, organic chemists, and researchers interested in oxidation mechanisms and radical chemistry will benefit from this discussion.
cuti_pie75
Hi,
It's been quite some time now I've spent on figuring out the mecanism of the oxydation of toluene with KMnO4 to give benzoic acid. My problem is i don't know how exactly the MnO4 attacks the hydrogen on the aliphatic chain. So, if anyone can help me figure out the first steps of which O on MnO4 will attack, that'll be great! :confused:
Chemistry news on Phys.org
Hello
In this process, either radicalic or cationic species form, as seen in a closely related reaction:
[tex]Ar_2CH_2+CrO_3\longrightarrow Ar_2C=O[/tex]
[tex]rate~determining~step:Ar_2CH_2 \longrightarrow Ar_2CH \cdot ~or~Ar_2CH_2 \longrightarrow Ar_2CH^+[/tex]
I'm certain about a benzyl cation or benzyl radical will be produced in this reaction you're asking about.
I think chem_tr is right. The first step is a hydrogen atom abstraction (that is, a proton plus an electron) to give a benzyl radical. That can then combine with a water molecule (water is typically the solvent for these oxidations) to give benzyl alcohol. The oxidation from the alcohol to the acid is much more straight forward and probably doesn't involve radicals.
15K
14K
9K
23K
