New Reply
Upward velocity of a block on a string
Share Thread Thread Tools
Sep29-11, 09:54 AM   #1
The force constant of a spring is 600 N/m and the un-stretched length is 0.72m. A 3.2kg block is suspended from the spring. An external force slowly pulls the block down, until the spring has been stretched to a length of 0.86m. The external force is then removed, and the block rises. In this situation, when the spring has the contracted to a length of 0.72m, What is the upward velocity of the block?
2. Relevant equations
conservation of energy
3. The attempt at a solution
KEinitial + Uinitial = KEfinal + Ufinal
0 + 0.5(600)(0.14)^2 = 0.5 x 3.2 x v^2 + 0
v = 1.92m/s?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Sep29-11, 11:02 AM   #2
Recognitions:
Homework Helper Homework Help
Don't forget that gravity is working on the block too!
Sep29-11, 11:20 AM   #3
0 + 0.5(600)(0.14)^2 + (3.2)(9.8)(0.14) = 0.5 x 3.2 x v^2 + 0
Is this right?
Sep29-11, 11:31 AM   #4
Recognitions:
Quote by ethex View Post
Is this right?
Better, but should the gravitational PE be negative? (It looks like you're taking the zero reference for it at the unstretched spring level).
Sep29-11, 11:43 AM   #5
Thank you, that is what i am missing out.
New Reply
Thread Tools
Similar Threads for: Upward velocity of a block on a string
Thread Forum Replies
Object thrown upward with known initial and final velocity Introductory Physics Homework 6
Block suspended on a string Introductory Physics Homework 17
Minimum string tension needed to move the block Introductory Physics Homework 20
Maximum Upward Acceleration of a String Introductory Physics Homework 2
given height, and velocity thrown upward, find air-time Introductory Physics Homework 8
