Conservation of Momentum of a uniform thin rod
The problem involves the conservation of momentum in a rotational context, specifically focusing on a uniform thin rod and a bullet impacting it. The scenario describes a bullet colliding with a rod that can rotate about a vertical axis, with the goal of determining the bullet's velocity just before impact.
  • Participants discuss the application of conservation of momentum and angular momentum principles. There are attempts to break down the bullet's velocity into components and questions about the correctness of the calculations performed. Some participants express confusion about the relationship between the bullet's velocity and the angles involved.
The discussion is ongoing, with some participants providing guidance on the correct application of angular momentum conservation. There is a mix of interpretations regarding the calculations, and while one participant claims to have reached the correct answer, they express uncertainty about their understanding of the underlying concepts.
Participants note the challenge of missing information regarding the bullet's velocity and the implications of the angle at which the bullet strikes the rod. There is also mention of seeking further clarification from a professor, indicating a desire for deeper understanding.
7C0A0A5
A uniform thin rod of length 0.40 m and mass 3.5 kg can rotate in a horizontal plane about a vertical axis through its center. The rod is at rest when a 3.0-g bullet traveling in the horizontal plane of the rod is fired into one end of the rod. As viewed from above, the direction of the bullet's velocity makes an angle of 60° with the rod (Fig. 12-44).If the bullet lodges in the rod and the angular velocity of the rod is 14 rad/s immediately after the collision, what is the magnitude of the bullet's velocity just before impact? [in m/s]
This should be a relatively easy problem, but I'm missing a concept somewhere. Please help.
First I thought that I could set Total Momentum before and after the collision equal to each other.
L = M can you do that?
[tex]L = I * \omega[/tex]
[tex]M = m * V[/tex]
[tex]I = {m_{final} * l^2}/12[/tex]
when solving these I got 0.04671 for L
and 218 for V
but that is wrong
then I used trig to find how fast that would be at that angle and got 252
which is also wrong...can someone please tell me where I'm messing up?
Did you first break the bullet's velocity into component vectors parallel and pendicular to the rod?
Well...it doesn't give me the velocity of the bullet and that is what I'm trying to find...so when I solved for the velocity I got 218 m/s. But that is the velocity perpendicular to the plane, right? so then I divided that number by the cos of 30 and got 252 which is also wrong.
No. What you want to do is apply conservation of angular momentum.
You may find this discussion helpful: https://www.physicsforums.com/showthread.php?t=52632
K thanks That thread did help and I got the right answer...don't fully understand why but I'll ask my proffesor during his office hours. Thanks a bunch guys.
  • · Replies 71 ·
  • · Replies 18 ·
