Calculating acceleration of an object tied to another object
  • Thread starter Thread starter trivk96
    Acceleration
The problem involves two connected objects, one on a table and one hanging, with the goal of calculating the acceleration of the hanging block as it descends. The context includes the masses of the blocks and the acceleration due to gravity.
  • Participants discuss the forces acting on the blocks, particularly the role of gravity and tension in the string. There are questions about how to account for both masses in the system and the relationship between the forces acting on the blocks.
Some participants have offered insights into the forces involved and the need to consider both blocks' acceleration. There is ongoing exploration of how to set up the equations correctly, with no explicit consensus reached yet.
Participants express uncertainty about the initial setup and the application of Newton's second law. There is a mention of a diagram that may aid in understanding the forces at play.
trivk96
Two objects are connected by a string of negligible mass. The 11 kg block is placed on a
smooth table top 1.8 m above the floor, and
the 7 kg block hangs over the edge of the table. The 7 kg block is then released from rest
at a distance of 0.9 m above the floor at time
t = 0.
Determine the acceleration of the 7 kg block
as it descends. The acceleration of gravity is
9.8 m/s2
Answer in units of m/s2
I have no idea.
Maybe- F=MA
I have no idea where to start, how to do this. I googled and found nothing. I am just lost
To see the diagram view the picture
F=ma is a good start. What are the forces acting on the 7kg block?
Gravity>>-9.8 m/s2
That means that the force is F= 7*-9.8=-68.6
So then that force acts on the 11kg which means for that weight, -68.6=11a would be the formula. a = -6.23636. Is that the acceleration?
Is the force just acting on the 11kg block?
I do not understand what you are asking. The force of gravity is pulling down the weight connected to the string so it pulls the 11kg weight at that force of gravity
But the two masses are tied together, so they are accelerating at the same rate. If you cut string, then the 7kg mass would fall with acceleration g, and the 11kg mass wouldn't move at all.
Another way to think about it is if you draw a diagram of the forces acting on the 7kg block: you have a downward force equal to its weight, but also an upward one which is from the tension in the string.
You're really close to the answer but you've got to remember that the weight of the 7kg block isn't just acting on the 11kg block.
So how would I include the other weight. Would I add the masses?
You have correctly said that the force on the 7kg block due to gravity is equal to 68.6N. But this force is pulling on the two masses, causing them to accelerate at the same rate. Sooo, using a = F/m you should be able to get an answer.
  • · Replies 24 ·
  • · Replies 25 ·
10K
