Kirchoff's Laws Problem - Power
  • Thread starter Thread starter KRC
    Laws Power
The discussion focuses on applying Kirchoff's Laws to determine the rate of electrical energy conversion to internal energy in resistors of 4.56Ω and 5.91Ω. The user attempted to solve the problem using the junction rule and loop rule but encountered discrepancies in their calculated currents (I1=2.7502, I2=-4.1340, I3=6.8842) and the expected results from their homework. A suggestion was made to adhere strictly to the chosen current directions and consider using nodal analysis for a clearer solution.
  • Understanding of Kirchoff's Laws, including the Junction Rule and Loop Rule
  • Familiarity with Ohm's Law and power calculations (P=I²R)
  • Basic knowledge of circuit analysis techniques, including nodal analysis
  • Ability to interpret and manipulate electrical circuit diagrams
  • Study Kirchoff's Laws in-depth, focusing on practical applications in circuit analysis
  • Learn about nodal analysis techniques for solving complex circuits
  • Review power calculations in resistive circuits using P=I²R
  • Practice solving circuit problems with varying current directions and voltage sources
Electrical engineering students, circuit designers, and anyone involved in analyzing electrical circuits using Kirchoff's Laws.
KRC
At what rate is electrical energy converted to internal energy in the 4.56Ω and the 5.91Ω resistors in the figure?
Kirchoff's Laws:
ƩI(in) = ƩI(out) Junction Rule
ƩΔV = 0 Loop Rule
I have set the top branch current to go from right to left = I(3)
I have set the middle branch current to go from right to left = I(2)
I have set the bottom branch current to go from left to right = I(1)
The left middle junction results in the following I(3) + I(2) = I(1)...Junction#1
Loop #1 = 0 = 6.96V-5.91I(2)-4.56I(3)
Loop #2 = 0 = -9.56I(1)-5.91I(2)+1.86V
I get I1=2.7502
I2=-4.1340
I3=6.8842
The answers I get when using the P=I^(2)*R...do not yield results consistent with the online homework
I have tried this several different ways and the answer according to my homework do not match. Please provide some insight here.
Thank You.
I think you're not following your own stipulations for current directions. Once you choose them, if you start writing equations you need to follow through.
When you "pass though" a resistor in the direction of the assumed current flow, you expect a voltage drop. If you pass through against the flow then you get a voltage rise.
Just a thought: you might find a nodal analysis approach to be easy to apply here.
  • · Replies 48 ·
