Introductory Solution Stoichiometry: Acids/Bases
The discussion focuses on calculating the grams of solid calcium hydroxide (Ca(OH)2) required to react with 14.2 mL of a 1.62 M nitric acid (HNO3) solution. The balanced chemical equation is Ca(OH)2 + 2 HNO3 → Ca(NO3)2 + 2 H2O. To solve the problem, participants emphasize the importance of first determining the number of moles of nitric acid using the molarity equation, followed by applying stoichiometry to find the required mass of calcium hydroxide.
  • Understanding of molarity and its calculation
  • Knowledge of stoichiometry and balanced chemical equations
  • Familiarity with the concept of moles in chemistry
  • Basic skills in unit conversion and dimensional analysis
  • Learn how to calculate moles from molarity and volume
  • Study stoichiometric conversions in chemical reactions
  • Explore the properties and reactions of acids and bases
  • Practice with similar stoichiometry problems involving different reactants
Chemistry students, educators, and anyone seeking to understand stoichiometric calculations involving acids and bases.
jacksonpeeble
How many grams of solid calcium hydroxide are needed to react with 14.2 mL of a 1.62 M nitric acid solution? Assume that the volume remains constant when the calcium hydroxide is added.
Ca(OH)2 + 2 HNO3 Ca(NO3)2 + 2 H2O
Molarity=moles of solute/liters of solution
I first balanced the equation (above). I know that I will need to set up the equation above with what information I have, and that I am looking for an answer in grams. However, I really don't know how to get started. Can someone give me the general outline/procedure for what to do with a problem like this (not necessarily this problem, although it probably can be verified that it is from OWL, so, as I'm sure many of you know, I can't go in and get this same problem anyhow.
Start calculating number of moles of nitric acid. Once you have moles it is an easy stoichiometry.
10K
